Go to Post Every year, 118 inspires our team to dream for the stars, and land on mars. If 118 wasn't there we wouldn't be off the ground. Think about it every superstar has critics. Keep doing what you do 118. - xSAWxBLADEx [more]
Unread 05-03-2013, 15:27
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Team 3647: Ultimate Ascent Robot
Hello all,
After catching up on some sleep we proudly present our machine to the rest of the world:
This year we have had almost complete 12/7 access to a full machine shop allowing us to create the best machine we have had since our rookie year in 2011. This is also the first year we have gone off the Kit Frame and machined our own WCD drive, coming off from our off season success with almost the same design.
We thank all the members, mentors and parents that have committed their time to make this happen, as well as our mainsponsors: SAIC, Nordson, Qualcomm and MakerPlace. Also to the various teams that have helped out us with parts and design.
The Drive: video
The popular West Coast Design: 2x1 Box with riveted gussets
WCP SS Gearboxes Geared for about 14FPS
WCP Live axel hubs and 4 inch Colson wheels
Custom machined GT2 5mm pulleys for drive, C-C + .005 for belt runs; has run beautifully for hours of practice.
Shooter:
Mini CIM geared up 2x using WCP gears
GT2 3mm Drive
4 inch colson wheels with WCP hubs up to 10,000 RPMs
BangBang Controller with KOP Encoders
Fixed Angle hits all 3 goals and the pyramid
3 Disk Auton Routine (may add more depending on time)
Loader and Intake:
550s and BAG CIM with VersaPlanetary Gearbox
GT2 3mm Drive
Custom Machined Pulleys for surgical tubing runs
Holds up to 4 disks
Intake allows for ground pick up
Hanger:
Two 2inch bore 6 inch stoke cylinders with hooks allows for level 1 climb
Can climb after the buzzer
Under 2 seconds to lift off the ground
In addition our build blog is now public: http://ultimate3647.tumblr.com/
Mostly just a photo dump of our progression.
We will be at San Diego Regional and Inland Empire.
Hope to have some fun matches and see everyone there.
If you have any questions feel free to ask, we have nothing to hid.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 05-03-2013, 18:40
karomata's Avatar
karomata karomata is offline
Rebellious Egyptian
AKA: Mo Elhelw
karomata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud of
Re: Team 3647: Ultimate Ascent Robot
Robot in 3 Days 2.0 O.O
Unread 06-03-2013, 03:27
Mk.32's Avatar
AKA: Mark
Rookie Year: 2011
I wish we could have built the entire in 3 days..............
The design process was influenced by the robot in 3 days group, and we would like to thank them for there amazing work to inspire and show what is possible with a simple design.
We agreed early on we wanted to be able to shoot every goal on the field mostly at close range (decided full court shooters would be blocked way to easy), have floor pick up and be able to hang at least the first level. After some thought going with juts level 1 allowed us to focus on the rest of the machine especially with auton being worth so much. I am quite glad we got the intake working as well as we did after seeing the week 1 events.
Unread 06-03-2013, 08:25
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Nice! Are your cylinders spring loaded? We used 1.5" no-spring cylinders and had a problem building enough pressure to pull up to the bar. We could do it, we had to let our air build up after we put the hooks in the "up" position. Looks great guys- good job with the floor intake, wishing you a successful competition season!
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 06-03-2013, 14:47
Mk.32's Avatar
AKA: Mark
Rookie Year: 2011
The cylinders are not spring loaded, they are just the ones from the bimba PDV. Which does mean we have to have about 30-35 PSI left in the tanks for them to be able to lift after the buzzer. We are only using our air for lifting/lowering the intake plus the hanger so in our practice we usually have plenty of air.
Thanks!
Unread 06-03-2013, 15:00
NXTGeek's Avatar
NXTGeek NXTGeek is offline
AKA: Malachi
Rookie Year: 2011
NXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to beholdNXTGeek is a splendid one to behold
Great job guys! Love the WCD
See you at SDR and IER!
-3476 Code Orange
2013 -Team 3476
Champion (Fall Classic)
Champion (Battle at the Border)
Finalist (Indiana Robotics Invitational)
Newton Division CHAMPIONS (Worlds)
Wild Card as Finalist Alliance Captain (Inland Empire -> Worlds)
Innovation in Control Award (Inland Empire)
Industrial Design Award (San Diego)
Semifinalist (San Diego)
2012 -Team 3476
Champion (San Diego -> Worlds)
Excellence in Engineering Award (San Diego)
2011 -Team 1425
Engineering Inspiration Award (Portland Autodesk -> Worlds)
Finalist (Portland Autodesk)
WFFA (Tim BD, Portland Autodesk)
Finalist (Seattle Olympic)
Entrepreneurship Award (Seattle Olympic)
Unread 06-03-2013, 15:06
I see, that's where we go wrong- we use air for every shot as well as our hopper. With that onboard compressor, you guys must be fine.
Unread 06-03-2013, 15:12
Mk.32's Avatar
AKA: Mark
Rookie Year: 2011
We were thinking about doing some kinda kicker for our shooter but decided like last year just a belt that ends as the disk enters to shooter would work fine. Also we have just learned to ALWAYS put the compressor onboard, last year we didn't and it was just a big hassle to deal with before matches and to find all the micro leaks.
Unread 06-03-2013, 15:19
DanielCH's Avatar
DanielCH DanielCH is offline
FRC #0295 (Renevatio)
Team Role: Driver
Rookie Year: 2010
DanielCH is an unknown quantity at this point
They may not be blocked as easily as you think.
I guess true innovation is when you can actually harness physics to do what you want. Heck -- that sounds suspiciously like engineering.
-- JVN
Unread 06-03-2013, 16:09
Really sweet robot this season, Mark. You should be extremely proud of the work you do for your team.
Wish you the best of luck dude!
Unread 06-03-2013, 18:25
DonRotolo's Avatar
Back to humble
FRC #0832
Nice build.
Here is a thought: add some latex tubing pulling 'down' on the cylinder rods. You always have enough pressure to extend, so extra force won't be a problem, but that same force will help lift you with less than 35 psi...
Unread 06-03-2013, 19:13
DanielCH's Avatar
Team Role: Driver
Rookie Year: 2010
They might not be blocked as easily as you may think.
-- JVN
Unread 06-03-2013, 23:51
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Originally Posted by DanielCH View Post
Was blue given a technical foul in this match?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 07-03-2013, 00:46
Mk.32's Avatar
AKA: Mark
Rookie Year: 2011
Honestly that to me looked like some successful defensive, even though blue did win. But neverless we may have to get some pool noodles to tape on incase we do need to play a defensive role...
  #15   Spotlight this post!
Unread 07-03-2013, 18:23
DanielCH's Avatar
Team Role: Driver
Rookie Year: 2010
Unless you shoot at a steep angle, you can get blocked, but what I meant was that even with some tough defense, full court shooter can still win with proper teamwork. We'll definitely be bringing some pool noodles as well!
-- JVN
