Go to Post There is a problem getting girls interested in STEM. Swift, immediate action is required. Continuing to stay the course leads to disaster. - Madison [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:18
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Important Tie Breaking News!
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems.
Posted on 11/1/2000 3:42 PM MST
After thinking more and more about the idea of no tie breakers in the Elimination Rounds, we have scared ourselves into reversing course.
We are very much afraid that it will be TOO easy to end up with a 0-0 tie over and over and over again.
So...
The following tie breakers will be used IN THE ELIMINATION ROUNDS ONLY:
#1 The alliance with the highest score based only on their color balls in squares on the ramps without regard to a) the color designation of the ramps and b) the position of the square rack.
#2 The alliance with the most balls on their side of the field ('their side' means the side that the drivers drive from and their color ramps are on). For the purposed of this tie breaker, EVERY ball will be ruled by the referees to be on the blue or the red side of the field based on an imaginary center of the ball and on an equally imaginary, infinite extent, infinitely thin plane separating the two halves of the field. We realize that some close calls will have to be made. We regret any bad calls the result in bad outcomes for your team. However, as with every other ruling they make, the referees' rulings are FINAL (and this time WE MEAN IT! ;-)
Note: Tie Breaker #1 will most likely mean that a non-zero tie will most likely be lost by a team that needed the doubler to tie the score.
There are other implications, of course, but I will leave them to be worked out as an exercise for the ambitious student.
Comments?
Joe J.
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
Where do you get your news MattK Chit-Chat 10 21-11-2002 17:15
News ... news ... yep... more news. Brandon Martus Announcements 3 23-06-2002 22:46
Good News Bad News archiver 2000 8 23-06-2002 22:45
Anyway to make it easier for readers to search for important info's? Ken Leung CD Forum Support 10 30-06-2001 14:47
