Go to Post My favorite is always "The Next One!" - Bill Moore [more]
Unread 05-03-2013, 19:31
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Team UPDATE - 2013-03-05
General Rules
G16
TEAMS and/or ROBOTS may not employ strategies that use DISCS to either aid or inhibit a ROBOT CLIMB.
Violation: TECHNICAL FOUL. If the DISC(S) inhibits an opponent’s CLIMB attempt, the opponent ROBOT’S ALLIANCE is awarded points for a successful Level 3 CLIMBwill be granted credit for a Level 3 CLIMB at the end of the MATCH.
ROBOT Actions
G27
ROBOTS may not contact or otherwise interfere with their opponents’ PYRAMID. Inconsequential contact will not be penalized.
Violation: TECHNICAL FOUL. If an opponent’s CLIMB is affected,
  1. [BLOCKQUOTE] RED CARD, and[/BLOCKQUOTE]
  2. [BLOCKQUOTE] Each affected opponent ROBOT will be awarded points for a successful Level 3 CLIMB granted credit for a Level 3 CLIMB at the end of the MATCH.[/BLOCKQUOTE]
ROBOT-ROBOT Interaction
G30
Regardless of who initiates the contact, a ROBOT may not contact an opponent ROBOT
  1. [BLOCKQUOTE] contacting its PYRAMID or[/BLOCKQUOTE]
  2. [BLOCKQUOTE] touching the carpet in its LOADING ZONE.[/BLOCKQUOTE]
Violation: FOUL. If purposeful or consequential, TECHNICAL FOUL. If an opponent's CLIMB is affected, each affected opponent ROBOT will be awarded points for a successful Level 3 CLIMB granted credit for a Level 3 CLIMB at the end of the MATCH.
Game Manual
General Announcements
A required update has been released for C++. This update fixes an error in the implementation of Network Tables feeding information to the SmartDashboard. It also fixes an issue with LiveWindow code causing crashes for teams using threads. Full release notes can be found on the 2013 Software Notes page. Our thanks to the teams and volunteers that helped us identify and troubleshoot the issues and solutions during Week 1 Events.
General note: TEAM Members may not lift other TEAM Members in the ALLIANCE STATION (either up on shoulders or otherwise) as this is a safety issue and will yield a Yellow Card per Section 5.5.4.
Q141 Change
After additional review, we are changing our answer to Question 141 on the Q&A. Once a robot has been awarded points for a Level 3 climb as the result of a penalty, it will no longer be eligible for additional climb points. The applicable rules are being changed to improve clarity.
Q: Per G16 and G27 a robot is awarded points for a Level 3 climb if their climb is interfered with. If the disrupted robot attempts another climb after the incident, is it eligible for additional climb points?
A: Yes. No.
C++ teams, make sure you install the update.
Unread 05-03-2013, 19:39
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Team UPDATE - 2013-03-05
Climb rule updates make sense, same as the balancing interference penalty last year. I was always assuming that's how it worked anyways, so I suppose it's good the GDC has come around to my way of thinking in time for our first regional.
Unread 05-03-2013, 19:50
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Given that there's no way in the scoring system to assign more than one climb level per robot, it only makes sense.
(since 2004)
Unread 05-03-2013, 20:27
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
They could just add 30 more foul points.
Moot point now.
Unread 06-03-2013, 04:06
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
Wow, so if someone gives a teammate a "lifting hug", they get a yellow card? There's a rule for everything now.
On the bright side, this is probably the most benign Week 1 update in awhile.
Unread 06-03-2013, 06:54
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
But foul points and climb points contribute differently to the rankings.
Moot point now.
Agree
(since 2004)
Unread 06-03-2013, 08:29
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Donut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond reputeDonut has a reputation beyond repute
Originally Posted by Chris is me View Post
Wow, so if someone gives a teammate a "lift "ing hug", they get a yellow card? There's a rule for everything now.
I'm hoping the referees don't call this one to the letter as it's written, though I suppose "lift" needs to be properly defined. I can understand why they would want to discourage something like a human pyramid from being built by the drive teams but a bear hug could bring about a yellow card if "lift" is interpreted as simply "no longer contacting the floor".
At that point why not just discourage jumping too? Then the drive teams can stand calmly and watch as the MC does a flip during their team intro.
FRC Team 498 (Peoria, AZ), Student: 2004 - 2007
FRC Team 498 (Peoria, AZ), Mentor: 2008 - 2011
FRC Team 167 (Iowa City, IA), Mentor: 2012 - 2014
FRC Team 2662 (Tolleson, AZ), Mentor: 2014 - Present
Unread 06-03-2013, 08:52
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Clarify this during the drivers meeting.
Blue Shirt Alaska Pics here and Amsterdam pics are here!!! and Puffin Pics
Unread 06-03-2013, 14:46
AKA: Pinecone
Frank clarified on FRC Blog. Wow, FIRST's ability to monitor community opinion is impressive! I feel kinda bad for making them respond to my cranky 6-AM-on-the-day-of-an-exam observation.
