Go to Post Its not the event that matters - its the preparation for the event that matters! - Ken Patton [more]
Unread 07-03-2013, 11:07
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Rookie Year: 2011
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
Question Hail Mary hang?
Where would i add a hail mary hang (Code to use our hanger at the last second) in the Command Based Robot Template? Would i use it at a command level or inside of teleop periodic?
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 07-03-2013, 12:26
UriF UriF is offline
FRC #2213
UriF is an unknown quantity at this point
Re: Hail Mary hang?
Well I'm not sure what you mean by that, but if you'd like to do some action at the last second of the match, I would suggest starting a Notifier function to run a second before the end of the match.
Unread 07-03-2013, 12:48
RPI 2018
AKA: Joe Iaquinto
Rookie Year: 2011
Re: Hail Mary hang?
To clarify, what file would i check the match time constantly and then use the notifier when the match is ending?
Unread 07-03-2013, 12:51
FRC #2213
Re: Hail Mary hang?
You wouldn't need to check the time constantly, you can simply set a Notifier up at the start of Operator period (outside of the OperatorControl loop, of course), and have it timeout after 2:15 minutes (not sure if that's how long operator period is).
Check out the Notifer class and its usage, I'm sure you will understand.
Unread 07-03-2013, 13:14
RPI 2018
AKA: Joe Iaquinto
Rookie Year: 2011
Re: Hail Mary hang?
Thank you so much! We have used notifiers before and it didn't occur to me to use them for this. Good luck at your competitions!
Unread 07-03-2013, 20:38
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
Rookie Year: 2007
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Re: Hail Mary hang?
Sticking with the command based approach. We created a command with a timeout of how long you want to wait from when the match starts. You schedule the command on teleop init. The IsFinished function returns IsTimedOut. Init and Execute are empty. Put the code to start the hail mary climb in the End function.
It's simple and it works.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 08-03-2013, 11:36
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
FRC #1418 (), FRC #1973, FRC #4796, FRC #6367 ()
virtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant futurevirtuald has a brilliant future
Re: Hail Mary hang?
I'm curious as to why you would have this be based on time, instead of as a button? Presumably activating your climbing mechanism at the very end is useless unless you happen to be in the right position...
Maintainer of RobotPy - Python for FRC
Creator of pyfrc (Robot Simulator + utilities for Python) and pynetworktables/pynetworktables2js (NetworkTables for Python & Javascript)
2017 Season: Teams #1973, #4796, #6369
Team #1418 (remote mentor): Newton Quarterfinalists, 2016 Chesapeake District Champion, 2x Innovation in Control award, 2x district event winner
Team #1418: 2015 DC Regional Innovation In Control Award, #2 seed; 2014 VA Industrial Design Award; 2014 Finalists in DC & VA
Team #2423: 2012 & 2013 Boston Regional Innovation in Control Award
Resources: FIRSTWiki (relaunched!) | My Software Stuff
Unread 09-03-2013, 07:48
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
Peyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond reputePeyton Yeung has a reputation beyond repute
I believe it is a measure that a lot of teams are using that will allow them to hang at the buzzer without needing to remember the button like if they were shooting last second from the pyramid it would automatically lift them.
461 Westside Boiler Invasion
2016 Tippy Quarter finalist, Warren Finalist, IN State Semi Finalist,B^3 Double Finalist
2015 Indy Semi finalist, Purdue Quarter Finalist, IN State Quarter Finalist, CORI QF, R2OC Finalist, RAGE Winner
2014 Boilermaker Semi finalist, Crossroads Quarter Finalist, & CAGE Quarter Finalist
45 Technokats
2013 Boilermaker Quarter finalist
2012 CAGE Semi finalist & Queen City Champion
2011 CAGE Quarter finalist & Midwest Semi finalist
2010 CAGE Quarter finalist, Boilermaker Champion, & Washington DC Quarter Finalist
Unread 11-03-2013, 10:04
JefferMC JefferMC is offline
AKA: Jeff Corbett
FRC #1319 (Flash)
JefferMC will become famous soon enough
Re: Hail Mary hang?
Yes, but to be effective the robot must know, or be able to obtain, its on-field position and orientation and use that to navigate to an open location on its pyramid and do the hang.
The "do the hang" is the simple part.
Unread 11-03-2013, 10:46
martin417's Avatar
martin417 martin417 is offline
Opinionated old goat
AKA: Martin Wilson
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
Re: Hail Mary hang?
Not if the shooting position and the hanging position are the same. That way they can concentate on getting the shots off without watching the clock.
Former Mentor Team 1771
Former mentor Team 4509
Unread 11-03-2013, 13:40
AKA: Jeff Corbett
FRC #1319 (Flash)
Re: Hail Mary hang?
Then you're assuming the position and orientation to be that of your shooting position. If it will not do you any harm to execute your last ditch move if this is incorrect, then I can see this as a valid strategy.
Unread 12-03-2013, 22:35
RPI 2018
AKA: Joe Iaquinto
Rookie Year: 2011
Re: Hail Mary hang?
To clarify, our hanging mechanism is powered by two pneumatic valves and 2 gas shocks. The hail mary was put in place just for the slim chance that the drivers are going to the pyramid at the end of a match and just barely make it and can't press the button to hang. The system eliminates that one disappointing match where we can't hang.
