Re: THE HORROR! THE HORROR!
They were simply failing batteries/cells that managed to emerge at the worst possible time. You can be sure we are taking measures to ensure that does not happen again.
Fortunately, Rob the head robot inspector, saw this once before with an AXIS camera and was able to point this out to us. |
Hah! 1551's pain was your gain! (Rob's first experience with the extreme wonkiness that can come from a frame-grounded Axis camera was at our expense.)
My panicking was meant to be taken with a grain of salt and was extremely sarcastic, hence the memes and star trek GIF. However, my questions about the integrity of the FMS last season (and possibly this season) is quite serious. While I make no claims to be able to diagnose an FMS failure over the web I can say with a high degree of certainty that our failure at WPI last year was not based on a fault in our code. We functioned normally for the entirety of the competition and had not experienced any previous failures. The FTA's at the event looked over our watchdog logs and our robot code at length and were incredibly helpful in trying to deduce what had caused our problem. They agreed with us that it was not an error in our code and even tried to get us a rematch to no avail. We have tried on multiple occasions to replicate our spinning on the field and have been unable to do so. I trust enough in the folks behind FIRST to believe that the FMS will be a non-issue but our experiences last year will never be too far from my mind. Last edited by Team23pitboss : 08-03-2013 at 21:48. |
And I appreciate that different people have different senses of humor, and that your graphics should have indicated your tone of sarcasm... but as the saying goes "TOO SOON...TOO SOON". |
We had problems also with all robots shutting down and having to play a rematch.
Not sure why frc still uses wifi, should move to independent channel RF. |
Also, what's supposed to happen when multiple robots trip the bandwidth limit? Last edited by coalhot : 12-03-2013 at 00:00. Reason: Got rid of the annoying meme... |
#11
I was behind the FTA table at GTR east this weekend learning how to be a score keeper. From what I could tell any problems that happened was because of the teams error. there was one team in particular who was dieing in the middle of matches all the time. The FTA's went to their pit and discovered the problem was in the program, (i'm not a programmer so sorry if I'm wrong) there was a problem where the amount of time between the robot reading the code was too slow. However the Programmer Refused to change the code for some stupid reason and kept blaming it on the field.
In FLR we had a problem where we died in 2 of our matches. the first match that it happened the FTA's quickly hurried to our pits to try and figure out the problem with our robot, as they knew the problem was not in the FMS. I am very pleased with the FTA's this year, and I am sure they don't want to have a year like last year. We figured out that the problem was the cRIO wiring, the two wires powering the cRIO were so close together that when we got hit by another robot we would die. The FMS system is working perfectly fine to what I can tell. For some reason it seems like some people are having issues with their code, where they get stuck in a "loop" and then their robot is confued, dies, or does the same thing it was just doing. Again thats the teams fault not the FMS |
#13
My point still stands: the FMS isn't the cause of most of the issues this year. From what I've seen, it has almost always is something in the code, or on the robot. Now, I'm not saying that it's always the fault of the robot. The Field breaks sometimes. However, the majority of issues so far from what I've seen (this year) have been code related. This is why I asked for the OP to post code and photos of the wiring, not only for us to be able to say "that's what caused the issue" (if it happened to be the robot or code), but also to look at it and say "that's something I want to avoid doing with my code/wiring/robot, so I don't have the same issues" Quote:
It's funny though, the camera seems to be the bane of all field issues so far this year (spotlighted by the FTA at NY regional having all the teams turn off their cameras for eliminations). What has changed between the past few years and 2013 that could cause issues like this, other than the bandwidth cap? Last edited by coalhot : 12-03-2013 at 11:23. |
#14
I don't know why teams exceeding the cap are affecting the rest of the field. It's not my area of expertise, and the FMS whitepaper does give many details on how the bandwidth cap is implemented. It does not seem to be working correctly, or at least how any reasonable person would expect. The logical assumption is that all teams are allocated 7mb/s, and any team exceeding that will be throttled so as not to affect the bandwidth of the other teams on the field. Any usage over 6mb/s sees a sharp increase in trip time, and will result in possible control lag (presumably only for the team nearing their limit). I would say that the camera is an issue primarily because of it's increased usefulness and the ability of teams to stream live feedback to their robots. In 2009, 2010 and 2011, this ability was not particularly useful and was note widely used. Last year, it was extremely useful for vision tracking or just for lining up shots. This year, I suspect even more teams have started putting robot-eye feedback, which seems to result in problems when several of these robots are on the field at once. The bandwidth cap may also be affecting things, since it limits each team to ensure that all teams will have an equal share, rather than dynamically reallocating bandwidth up to the maximum the system can handle to accommodate for a few robots using more than their even share. |
#15
