Go to Post Everyone needs to please stop now before Karthik starts singing. - dlavery [more]
Unread 03-08-2013, 10:39 PM
toastnbacon toastnbacon is offline
AKA: James
FRC #3169 (Saintborgs)
Rookie Year: 2010
toastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the roughtoastnbacon is a jewel in the rough
Question Computer cluster? (Not FIRST related)
First off, sorry about posting this question here, I didn't know where else to go where I could get help.
But as to the actual question: I have two computer towers running Windows XP and another tower without an OS. I also have a Dell laptop running Windows 7. What I want to do is somehow use them in tandem (as a cluster? Not sure if that's the right word...) as a regular home computer. I sometimes push my laptop too hard, and I'm looking to speed it up in any way. Is what I'm wanting to do possible, and if so, how? Thank you in advance!
"This must be what going insane feels like."-Simon Tam, Firefly
Unread 03-08-2013, 10:52 PM
arun4444 arun4444 is offline
FRC #3760
arun4444 has a little shameless behaviour in the past
Re: Computer cluster? (Not FIRST related)
Not possible to use as a regular computer running windows. There are however cluster based OS like
http://www.kerrighed.org/wiki/index.php/Main_Page
but it will be far from your familiar windows based desktop experience - all you will get is a linux shell and the OS will automatically hop processes over the network to slave nodes. Pretty good for determining protein structures, calculating pi to zillion digits - but not for desktop computing - because not all algorithms are easily parallelizable.
cheers
arun
Unread 03-08-2013, 11:09 PM
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
Rookie Year: 2012
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Not exactly sure what your asking, but this is awesome - I use it at home between 2-3 computers (2 desktops and a laptop). http://synergy-foss.org/
All opinions are my own.
Unread 03-09-2013, 01:19 AM
AKA: James
Rookie Year: 2010
Sweet, I'll take a look at those! Thanks!
Unread 03-09-2013, 02:12 AM
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
I don't know of any good way to do generic load-sharing amongst computers. If you have specific tasks you want to run on the tower PCs, there are probably lots of ways to automate and control those from another computer. You've have to give us more details on exactly what you're trying to do for us to help.
I suspect that your XP machines (3+ years old?) have very little to offer the Win7 laptop (1 year old?), which I'm guessing is more powerful than all the towers together. In what way are you stressing the laptop? RAM? Graphics? Heat?
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 03-09-2013, 09:06 AM
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
Rookie Year: 2007
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
My opinion and past experiences is that building a cluster with old computers is just not worth it. Back when P4s were common I made a small 8 node cluster with 8 P2s (300Mhz). The combine processor power was 2.4ghz. Most P4s at that time were 2.8 Granite I did have 8 cores on the cluster.
With that being said I found Cluster Knoppix was the easiest to use. Cluster Knoppix is a live CD so you don't actually have to install it. You just have to boot from the CD. Once one node is up you boot others off of it's PXE/DHCP server. If not other DHCP is on the network and computer is configured for network boot it will automatically boot up Cluster Knoppix and join the cluster.
Chaos Linux is another alternative that uses OpenMosix which is what allows the clustering.
OpenMosix regardless of which version you use will automatically move processes to idle nodes as the you start to take the CPU.
A quick Google OpenMosix, ClusterKnoppix, or Chaos Linux will get you started.
Good Luck!!!
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
