Go to Post You will find that most people in good companies are real people that share the same values and concerns as all of us. - ebarker [more]
Unread 03-08-2013, 11:33 PM
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
Rookie Year: 2012
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
5 second delay on gyro resetting?
Originally Posted by thinker&planner View Post
Java has a 5-sec delay when it resets the gyro (andymark) which our whole drive system is based off of (orientation to the field)
Is this really true? Can anyone verify this?
All opinions are my own.
Unread 03-08-2013, 11:35 PM
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: 5 second delay on gyro resetting?
The constructor for the WPIlib Gyro class calls a blocking init() method that has sleeps of 1 and 5 seconds (~6 seconds total). However, this method is only called upon construction of a Gyro object - NOT when simply calling the reset() method.
The constructor calibrates the gyro, while reset does not change calibration but rather sets the current angle to 0.
Unread 03-08-2013, 11:46 PM
AKA: Joel Gallant
Rookie Year: 2012
That was what I thought. Thanks.
