Thread Tools |
Rating:
Display Modes |
Re: What did we learn from week 2 of the 2013 season?
However, this does, to my untrained brain, contradict another FTA statement from Horsham: that when we and another team turned off our dashboard for the match in question, everyone's trip times got better. At least, I that's what I thought he said. It seems counter though, so unless someone else has knowledge of a similar situation, I'll assume I misinterpreted him.* Nonetheless, they did not start the match until after this discussion, and it took quite some time to determine it. (They also found another router that needed to be turned off before this dashboard investigation began. Both elements took some time, not that I fault anyone at all for it.) *EDIT: I guess so then. Is it possible that the bandwidth limits only identify the team that is exceeding them, rather than stopping them all together? Then again, I don't know why we would have had the choice to leave ours on if it was affecting others (and we certainly wouldn't have had we known, not that we didn't anyway). And apparently NYC didn't know who was causing it. Ok, so scratch that idea. What I learned from Week (1-)2: apparently there's still more education needed to sort out FMS bandwidth issues. In other news - I learned to make sure I remind drive teams to look for discs fallen and stuck on your robot (count towards your 4), and also that G30 only applies when you contact your loading zone carpet--not when you break the plane. I also learned that pyramids come apart up to 1/4" in normal match play, and that you absolutely, positively have to wait for the green lights before entering the field. Oh, and that if no one warns them, the lighting crews may want to do some really crazy (cool) light tricks on the vision targets, in autonomous, in the finals. ![]() Last edited by Siri : 10-03-2013 at 20:04. |
I learned that, no matter how many times they win a regional, the thoughts of "maybe they won't win this year" won't come true for 2056.
15 regionals attended since their creation. 15 wins in that span. You guys are so amazing to follow year after year. |
At the same time, don't count the full court shooter out just because there's a pool noodle in the way. A team at Waterford had their blocking mechanism broken by flying frisbees.
Do you have a video? For what not to do for a "net".
Defense can shut teams down, and is only going to get more rough.
#10
This may be the year of the drivetrain. teams with powerful drivetrains that can both push bots around and zip across the field will be able to avoid most defense or win most pushing matches.
#11
In the second finals match, 2826 was firing full court shots faster than 2169 could. We managed to block 10 of their shots with our disk hopper - it was never intended for this and there was a risk of damage to it, but you do what you need to when necessary.
#13
Yeah, that was awesomely done - you saved us the match.
I think that this is a harbringer of a very successful alliance pattern at world- a full court shooter, a blocker/collector/pyramid shooter, and a counter- blocker. For the most success, all robots should have 18 point autos, and the blocker/collector should probably have a 5-disc (though I don't think anyone had one of those at northern lights). All robots should also be able to score if thier role is not needed (for example, running out of frisbees wasnt a massive problem for us, so you guys could run feeder-station cycles shooting from close in instead of collecting and putting those in. Or, like how against the rookie alliance (rock solid and that group), when there was no 84 inch blocker, 3061 was able to score points. |
#14
This was an excellent learning experience for everyone. It was great to see teams innovate on the fly and come up with creative solutions with what limited time and materials they had. This is exactly what FIRST is all about. Don't ever give up, keep on innovating, root for the underdog because you never know what new ideas they will try.
For us as a team, this was a gift. We knew that it would eventually happen though we did not know what form it would take. This allowed us to try different counter strategies and it made for some exciting matches. Sincerely, from team 2169, thank you to all of the teams that forced us to get better. We hope to proudly represent Minnesota at the World Championships. |
#15
Besides, since they (2169, 525, 3061) :
I guess they were not overly upset by improvised blockers. Last edited by MisterG : 11-03-2013 at 15:48. Reason: grammar |
