Re: What did we learn from week 2 of the 2013 season?
Oh, not at all. They had a very solid anti-defense against our alliance in the finals. I was one of the drivers and they almost entirely shut us down(We were the defensive bot in the alliance). We had played against a team earlier in finals that also full court shot, but they didn't play a strong anti-defense like KingTec's alliance did.
Aim high!
We planned to score 62 points every match. 12 in autonomous, 30 hang, 20 dump on top. We never actually achieved this goal. But we aimed high and stuck it out, doing what we could each match and ended up placing 7th in the competitive Orlando regional, and competed for the 4th alliance in eliminations. We learned a lot and sure are ready for the South Florida Regional! |
He means that bumpers ruining a hang can change the outcome of a match.
Full court shooters are vulnerable to defense (see 1138 and 2339 at SD) and the double defense strategy beats teams with no ground pickup.
1. Like a broken record... Autonomous, autonomous, autonomous, autonomous.
2. By week 4-6, every full court shooter is going to be ineffective. It is too easy to block them. One trick pony. 3. Refs are not aware of the absence of a starting configuration height rule. Our match start was delayed because we attached tall plastic straws to our 2nd alliance partner. The head ref argued with us for a good 5 minutes before someone would do a rule check. If you plan on attaching pool noodles last second, be ready to explain why it is legal. |
We learned that no matter the outcome when you don't give up you will always win.
That the FIRST community will always step up in times of need (Robodawgs trailer getting stolen, along with 1592 and 801 robots being tore up in a accident).
Didn't learn much that I didn't already see in Week 1. In no particular order:
Climbing for 30 is not a ticket to victory. Full court shooting is like fender shooting in 2012 - its great until a defender comes along. To be effective, you need to set up quick, be accurate, and be prepared to leave and shoot from the pyramid when needed. Variable elevation shooters are the biggest cause of missed shots/reduced cycles for so many teams. First, because teams just miss. Second, because it slows the whole cycle down (position robot, adjust shooter, shoot, adjust, shoot, adjust, shoot, shoot). Time at the feeder station is just as import as time spent anywhere else. Practice lining up, practice feeding discs. Practice, practice, practice. Floor pickup is a good thing, even if you don't use it all the time. Every alliance should have one. Reduce cycle time. Autonomous. |
With median OPR last week being at 13, every cycle at the feeder station and making the shots is worth about 1x the median OPR. Thus, every extra cycle puts you way above the rest of the competition. ************************************ I saw a handful of teams this weekend capable of putting up 70+ points per match, but a consistent 50+ seemed to get you ranked higher than a 30-70 range machine. |
#10
Stay and play full-court shooting can easily be taken down, but if you have a robot that can set up quickly, fire of a few accurate shots, and get the heck out of there and pyramid shoot when under defense, then go back to full-court when there's no defense, you've got yourself a strategically successful machine that can't be stopped. |
#11
We are not a full court shooter bur our experince was you have to keep the other alliance guessing. In early matches we went to midcourt and sucked up the extra discs in that area with our floor pick up. When that was defended more we went into the opposite side to get the discs there and used our speed to quickly get back to our position under the pyramid to shoot and go look for other discs and so on. When a partner was shooting from our normal position we would shoot from outside the pyramid or work in beside them if there was room to shoot but do whatever you are doing fast and keep the other alliance guessing. We have a pretty strong drive train so sometimes we would block a opponent from their feed station on our way to collect discs. It slowed us down but it also aggrevated the other team and put them off their strategy. Adapt and over come. |
#14
I read on twitter than when 801 made it to the field the whole venue stood up and cheered for them, and I nearly cried with joy. The FIRST community can truly be a beautiful thing. |
#15
1138 Eagle Engineering(also one the 254/987 alliance) had pool noodles on their robot for blocking and blocked team 2485, the Warlords, from using their awesome full court 3 point shooter, which is one of the reason that the Warlords lost
