OPR after Week Two Events
The OPR/CCWM numbers have been posted, please see
http://www.chiefdelphi.com/media/papers/2174 There are a number of points I would like to make: 1) Central Valley data is now complete. 2) One match in New York regional is missing. Based on time of match, it looks like it is a replay match but there is no score. I put in 0-0 for now so I can post the results. I will recalculate the OPR/CCWM once that match data is available. 3) Toronto East regional is missing finals results. However it does not affect all the data posted since I know the outcome of the finals from other CD threads. 4) Northern Lights regional data is missing. 5) FIRST changed the headings of Team Standings page this week. Last week they were using last year's heading with HP, BP, TP and CP. This week they changed it to AP, CP and TP and took out the Coop Points (CP). Unfortunately they did not repost the Week One events with the new headings. This creates problem in my spreadsheet and creates unnecessary work. Enjoy the data! If you find any error or have any questions, please let me know. Last edited by Ed Law : 11-03-2013 at 11:39. |
Wow, thank you so much for this! We are 27th... And great job 987 on being 2nd!
Re: OPR after Week Two Events
So... OPR vs CCWM. I understand how they're calculated, I'm just not sure what the meaning of the distinction is.
Many high end teams have equal or nearly equal OPR and CCWM ranks (2056, 1114, 1986, 610, 987, 118), but other strong teams, like 4343 and 1241 have significantly higher CCWM ranks than OPR ranks. I wonder what that means. Anybody have an idea of why this phenomenon occurs? That said, even MORE proud of the kids on 4343 for being 8th in the world for CCWM after 2 weeks of play. |
Ed,
At Waterford 4 of our 12 matches were played with only a two team alliance. Do you have any factor that plays into the CCWM and OPR calculation? |
Northern Lights regional is missing, but I also have noticed that the FIRST website has not updated either.
Are the Auto, Climb and Teleop OPRs on the WorldRank sheet supposed to match the individual event teams have played so far? It looks like they did in last week's version, but this week, for instance, has 2056's OPR-T at 2.13. (Crazy enough on its own, but GTR-E has it at 46.)
EDIT: It looks like columns A-T got sorted after everything was calculated. 1640's columns AA-AC look to be listed with team 4557 at rank 290. 2590's are with 3755 at 409th. Is there a simple way to fix it? |
If a team's score is only high when there is a strong partner and it is low without a strong partner, then their OPR/CCWM will be low and rightly so. |
Are individual event opr's supposed to match the world rank ones, even if a team has only competed once? They seem to be off by a bit, not much but a bit.
#10
At events where no team had played twice, the OPRs should match. Those events are Central Valley, Hatboro Horsham, San Diego, Lake Superior, Northern Lights, and Oregon. |
#11
This scoring contribution is not true of other potential DQs, for instance the entire team no-showing or playing without clearing inspection, but it does apply for some. It could work if you had Disable information or no-show robots (vs 5.5.6 no show teams), but DQ might be a wash this year. |
#13
The reason why the data for Northern Lights is missing is because of the special match that they played between the NL winners and the Lake Superior winners. When they tried to sync the robots to the field they couldnt because of FMIS system so somehow in that process they also wiped the match data from the FRC system. Hopefully they will repost the data sometime this week.
#14
What do you guys think of OPR this year? It seems like based on a comparison of WPI's rankings versus the actual data we took, it is better than using ranking to sort teams, but still pretty noisy. I know our team's OPR was a bit low. I bet this was due to getting a lot of matches with other good teams at the regional where the score was lower than you'd expect (robot failures, etc). The other teams are ranked at least in the right ballpark, but not in a very solid order. 1100's OPR rank of #6 in particular is criminally low.
#15
