Go to Post If I'm going to mentor someone, I'm going to be involved in their life as a positive force. - Mechvet [more]
Unread 12-03-2013, 11:33
viveksridhar viveksridhar is offline
FRC #2367
viveksridhar is an unknown quantity at this point
Good Rotational Sensor
Does anyone know of a good rotational sensor?
We want to try implementing a swerve drive for next year, and we need a rotational sensor to have precise control over how much each of the wheel modules rotates.
We're planning to use BaneBots motors to drive the pivot, and at first I thought that we could use encoders on them, but I'm not sure how to mount encoders on a BaneBots motor. Is there a way to do that? And if not, what sensor would I use to measure the rotation of the wheels?
Thanks,
Unread 12-03-2013, 11:38
Tanaythan's Avatar
Tanaythan Tanaythan is offline
Programmer
AKA: Tanay Nathan
FRC #3256 (Warriorborgs)
Rookie Year: 2010
Tanaythan is an unknown quantity at this point
Re: Good Rotational Sensor
Wouldn't it be simpler to use servos instead?
Tanay Nathan
Programmer
Team #3256 Warriorborgs
Unread 12-03-2013, 11:43
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Servo's are not strong enough to rotate a swerve base... at least the one's we can use.
The one year we did swerve, we used US Digital MA3 Absolute Shaft Encoders: http://www.usdigital.com/products/en...tary/shaft/ma3
They will give you your position using an analog voltage from 0V to 5V, they allow roll over, and they work straight from an analog pin (5V supply). You also have the choice to use a digital mode which produces a pulse width based on the current angle.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
Rookie Year: 2012
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
FRC-legal servos don't have enough torque to turn a swerve module. In effect, adding a feedback sensor to a motor makes it a servo, as a servo is simply a gearmotor with a potentiometer for feedback.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 12-03-2013, 11:48
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Look for a potentiometer or absolute encoder with analog output.
We've used standard 1,3,5,10 turn pots for things like this (anything 10k to 100k will work). We've also used US Digital MA3 magnetic absolute encoders, those are nice as well.
Relative encoders (such as the quadrature encoders in the kit) are not absolute. They can tell you how far you have gone, and how fast you are going, and what direction, but cannot give you any zero position reference. For a swerve, since you don't know where the pods are when you boot up or if they ever move when you are powered off or reboot, you would like an absolute sensor like a potentiometer.
Building a swerve is hard. Don't underestimate how hard it is. Also don't overestimate how much benefit you will get. Mounting a sensor to the swerve pods is part of the many mechanical design challanges you will encounter while building a swerve drive. One method of mounting the sensor is to make it inline with the steering chain.
Kettering Motorsports
Unread 12-03-2013, 12:21
FRC #2367
How would that encoder fit onto the output shaft of a BaneBots motor? I don't think the gearboxes for those motors have a separate encoder shaft either.
Unread 12-03-2013, 22:26
ablatner ablatner is offline
AKA: Andrew Blatner
FRC #0100 (The Wildhats)
Team Role: Leadership
ablatner is on a distinguished road
It doesn't have to be on the motor shaft. It could be on the module's rotation shaft or an intermediate shaft.
Unread 12-03-2013, 22:38
DonRotolo's Avatar
Back to humble
FRC #0832
We have had a good experience with Grayhill model 63R encoders, which we bought from DigiKey.
Unread 12-03-2013, 22:47
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
For our swerve drive encoders we use the 1/8" shaft Ball-bearing version of the Analog MA3 encoders from US Digital. To hook the shaft to the Banebots output we used surgical tubing. We ziptied one end to the encoder shaft and the other end we ziptied to a piece of #10 all thread screwed into the banebots P60 shaft. In general surgical tubing works very well as a low-load flexible shaft adapter.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
