Go to Post Just take a chance. Dream and live. It's not a wild decision, but just ask yourself - if I got my team just a little bit more spending money, where would my team be then? Then, change that dream into a reality. Help your team sustain itself to inspire more kids. - CalTran [more]
Unread 12-03-2013, 18:14
Reggie335 Reggie335 is offline
AKA: Reginald
FRC #4297 (WeNoRobots)
Team Role: Leadership
Rookie Year: 2011
Reggie335 is an unknown quantity at this point
pneumatics
can anyone help me find the reason of why my programming to my pneumatic system will not work. I have done exactly what was suppose to be correct by programming the air compressor, solenoid and relay and they were all done through the VI's that they were suppose to be programmed in and on the buttons that i want them on but it just won't work.
Unread 12-03-2013, 19:00
jcbc's Avatar
jcbc jcbc is offline
AKA: Julie
Rookie Year: 2011
jcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the rough
Re: pneumatics
We had issues using the compressor control loop VI. We found this post and used the code shown in the periodic tasks section instead of the compressor control loop VI. Our pneumatic system has worked ever since.
Hope this helps you!
Unread 12-03-2013, 22:15
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pneumatics
Many of us could probably help, but not if we can't see your code. Show it to us and we'll see if it looks okay.
Did you try the example projects (they are known to work correctly) to see if the problem might be in your wiring?
Unread 12-03-2013, 23:48
AKA: Reginald
Rookie Year: 2011
Re: pneumatics
Here is our Begin.vi and Teleop.Vi
ID:	14332  Click image for larger version
Unread 13-03-2013, 00:14
lorem3k's Avatar
lorem3k lorem3k is offline
1 + 1 = 0 (in Z/2Z)
AKA: Andy D.
FRC #1482 (Bishop Grandin Ghosts)
Rookie Year: 2011
lorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to beholdlorem3k is a splendid one to behold
Re: pneumatics
Can you also post your Periodic Tasks.vi? Aside from that, it looks like some of the spacing on your refnum names is kind of wonky. Make sure that they're exactly the same across your .vis.
Boo! Bishop Grandin High School / GM Canada / Tenaris
2013 Western Canada - Quarterfinalists (thanks 288/4719) / 2012 GTR West - Quarterfinalists (thanks 188/1075) / 2011 GTR East - Regional Winners (thanks 1114/1503)
Unread 13-03-2013, 00:26
AKA: Reginald
Rookie Year: 2011
Re: pneumatics
Here is our Periodic Task.vi
Unread 13-03-2013, 00:30
lorem3k's Avatar
1 + 1 = 0 (in Z/2Z)
AKA: Andy D.
Rookie Year: 2011
Re: pneumatics
From what I can see, it looks like you have two spaces between "Air" and "Compressor" in the refnum you set in Begin, but only one space in Periodic Tasks.
Unread 13-03-2013, 00:41
AKA: Reginald
Rookie Year: 2011
Re: pneumatics
Ok Thanks i will try it in the morning also should all of the light on the solenoid breakout module be on
