Re: Level 3 Point Upgrade for Champs?
If the scoring had been higher for climbing out of the gate we would have factored that in and maybe went a different direction. |
The core imbalance is that a relatively trivial capability on all three alliance robots - 10pt hang following the 3-day robot example - gives the same score as the much harder and riskier challenge of climbing the pyramid. As several posters have already said, dropping the level 1 score to 5-7pts is probably the most likely action if there is any scoring change for Championships. |
A lot of teams worked very hard building robots that would be competitive given the current scoring system. I'm sure many of those teams knew St Louis would be a different kind of beast and changed their designs accordingly. I just don't see how someone could justify changing the scoring system given the amount of planning and work that would be wasted if the scoring system was changed.
Perhaps those teams predicted correctly how the game would be scored as is, but also consider MikeE's point quoted above. I would be pretty disappointed at the end of the season if I felt like the hardest task FIRST has even assigned was undervalued. In a 150 point match, it only counts for 20% right now. I think FIRST reserved the right to change the point total to see how the game played out. |
I'm pretty sure the number of robots that can score 40+ can be counted on one hand so far. And you need to be comparing teleop time to climb time. Since that is when both would be taking place. Probably about the same number of really good shooters can score 30pts in the last 45 seconds that can climb for 30pts in the last 45 seconds. It seems pretty even to me. I agree that this may be one of the hardest tasks FRC has given but at the same time they also released the point values. Knowing both should have determined your teams build strategy.
There are 12 teams that have an autonomous OPR of greater then 18. There are 13 teams with a climb OPR greater then 18.
Yes, we all started with the same rules, including:
#11
My primary complaint is the people that built solely hanging robots and complained that "we tried the harder challenge and aren't being rewarded like we thought we would be". |
#12
Our build strategy thoughts were:
I don't think, given the way the GDC has adjusted the rules in the past, that you can design a bot for a static strategy. Those who say - "This isn't fair, I didn't account for any changes by the GDC" - are going to find it more difficult to advance at Championships. Steve |
#13
Other thought: How different would the game be if hanging for 10 was changed to hanging for 0?
#15
What I am seeing is lots of posts from people who did not build a pyramid climbing capability into their robots and didn't read the rules completely now complaining that "we don't want any changes to rules which currently benefit us, so that they potentially benefit others". And there is nothing wrong in that view until it gets wrapped up in self-serving and sanctimonious claims of "fairness". I don't expect to see a change at the Championships. But as I stated earlier if there is a change I'd expect a moderate adjustment downwards for a level 1 hang rather than an increase in level 2 or 3 climbing. |
