Go to Post After all, professional engineers know The Right Way To Do It (TM) and if we knew that we'd be deprived of the educational experience of screwing up. - phrontist [more]
Unread 14-03-2013, 20:05
omsahmad's Avatar
omsahmad omsahmad is offline
FRC #1595 (Dragons)
Rookie Year: 2011
omsahmad is just really niceomsahmad is just really niceomsahmad is just really niceomsahmad is just really niceomsahmad is just really nice
Where does Windriver printf
So I know you can setup smartdashboard or DriverStationLCD, but where does Windriver print a line if you just put in the following (as seen in vision example):
Code:
	if(scoreCompare(scores[i], false))
		printf("particle: %d  is a High Goal  centerX: %f  centerY: %f \n", i, report->center_mass_x_normalized, report->center_mass_y_normalized);
		printf("Distance: %f \n", computeDistance(thresholdImage, report, false));
	} else if (scoreCompare(scores[i], true)) {
		printf("particle: %d  is a Middle Goal  centerX: %f  centerY: %f \n", i, report->center_mass_x_normalized, report->center_mass_y_normalized);
		printf("Distance: %f \n", computeDistance(thresholdImage, report, true));
	} else {
		printf("particle: %d  is not a goal  centerX: %f  centerY: %f \n", i, report->center_mass_x_normalized, report->center_mass_y_normalized);
	printf("rect: %f  ARinner: %f \n", scores[i].rectangularity, scores[i].aspectRatioInner);
	printf("ARouter: %f  xEdge: %f  yEdge: %f  \n", scores[i].aspectRatioOuter, scores[i].xEdge, scores[i].yEdge);
printf("\n");
DriverStationLCD is pretty limited and I am still figuring stuff in SmartDashboard.
Thanks.
Unread 14-03-2013, 20:12
Tanaythan's Avatar
Tanaythan Tanaythan is offline
Programmer
AKA: Tanay Nathan
FRC #3256 (Warriorborgs)
Rookie Year: 2010
Tanaythan is an unknown quantity at this point
Re: Where does Windriver printf
Printf's go to the NetConsole for cRio or to the target console that can be accessed from Windriver. NetConsole is much more convenient as it does not go away when the cRio reboots; if you enabled NetConsole with your cRio imaging tool, I highly recommend the use of NetConsole. You can monitor all printfs from there.
Tanay Nathan
Programmer
Team #3256 Warriorborgs
Unread 15-03-2013, 14:40
omsahmad's Avatar
FRC #1595 (Dragons)
Rookie Year: 2011
Awesome, thanks
Unread 15-03-2013, 15:45
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
Rookie Year: 2007
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Just be careful of sending a printf() in your while(IsOperatorControl()) loop. The frequency of such a thing is very high and will quickly swamp the network/cRio etc. Often we will use a static int counter or a timer.HasPeriodPassed(500) to only allow a printf to occur a few times per second.
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 15-03-2013, 21:18
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
Rookie Year: 2011
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
^This. Another good option is to printf() in a separate task that sleeps for 100ms or so every loop - we did this for our DriverStationLCD stuff and any printf()s we needed for debugging last year.
FRC 612 '12
USNA '16
