Go to Post My code mentors once told me, "A good programmer can look at a library, decide he hates it, and code everything from scratch. An amazing programmer can look at a library, decide he hates it, but realize the time it will save him and learn to use it." - slavik262 [more]
Unread 03-16-2013, 03:49 PM
eaglesfan51520's Avatar
eaglesfan51520 eaglesfan51520 is offline
Lead Programming Mentor
AKA: Steve
FRC #1687
eaglesfan51520 is an unknown quantity at this point
Strange C++ Update Error
We are having issues with the new C++ Updates. The issue is only present while we are connected to the robot over Wi-Fi. The issue is about every 5 seconds or so a momentary dropout occurs(Robot Code Flashes Red for an instant on DS). We believe it is in the library because we recompiled our old code which did not have the issue with the new libraries and the error occured. We have been able to replicate this error on 3 different cRio(one of them being an 8-slot), both versions of the Router(Revision A and B), and also changed out all the Ethernet cables to make sure they were not causing it.
Quick Notes About Our Setup:
No Dashboard Used(Configured to Remote Dashboard in DS)
No Network Tables Calls in Code
Routers Configured Using FRC Bridge Utility to be 2.4GHz
CANJaguars controlled by 2CAN 2.0(All latest firmware IFI Jags)
Any other teams have this issues?
