Go to Post still emotion conveyed through text is really strange. - Blackphantom91 [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:24
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Keyang Motor Thermal breaker.
Posted by Rod Prather.
Engineer on team #234, Cyber Blue, from Perry Meridian High School and Rolls Royce.
Posted on 11/9/2000 11:22 AM MST
According to the app notes, the keyang motors have a self resetting circuit breaker. Are there any parameters for this breaker? Ex: time required to reset, current vs time, max stall loading. It appears that although the motor has a stall current of 20 amps, it won't sustain a stall for any period at all. We have a motor that is popping this breaker at about 50% to 60% loading for only 15 seconds. (guess not measured)
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
I2R heating
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems.
Posted on 11/9/2000 12:15 PM MST
In Reply to: Keyang Motor Thermal breaker. posted by Rod Prather on 11/9/2000 11:22 AM MST:
I have not observed a wide variation in trip times from motor to motor.
Basically the breakers trip based on the temperature of the motor which is a function of the ambiant temperature and the amount of heat you put into it. The heat you put into it is basically I squared R heating.
More current for more time means more heat to dissipate.
My experience is that if you are asking the motors to do too much (specifically working too close to stall conditions), the breakers overheat too fast.
That said, there is often a fine line in these FIRST-type competitions between asking for too much and asking for enough to win!
You will have to decide where that line is.
Good Luck.
Joe J.
[IMG] code is Off
Main on/off breaker Brett W Technical Discussion 4 07-01-2003 23:35
Strategies to prevent overcurrent/breaker trip kmcclary Motors 27 28-12-2002 01:00
circuit breaker archiver 2001 2 23-06-2002 23:18
60 amp breaker Anne Lam Technical Discussion 10 10-01-2002 15:13
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
