Go to Post But if we just re-play "Triple Play" then what in the world will the Game Design Committee do with all that new-found free time? Since they wouldn't have to come up with a new game, they would have to concentrate on other things - like how to enforce the proposed "no metal on robots" rule. - dlavery [more]
Unread 18-03-2013, 21:25
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
80-100% CPU usage
My dad is having issues when running code on the cRIO. The cRIO is running at was is being reported as 80-100% CPU usage causing it to act sluggish and lag a lot. I do not have access to his code but I can get it this weekend when I go home. When he runs the default code I believe he said it was 50-60%. Any one see anything like this before? If so what was the cause of it?
Unread 18-03-2013, 21:28
engunneer's Avatar
engunneer engunneer is offline
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Rookie Year: 1996
engunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond reputeengunneer has a reputation beyond repute
Re: 80-100% CPU usage
check for unneeded loops. This is the #1 for me to look for. I generally advocate for loopless code (outside robot main and periodic tasks).
Do you have vision code?
Student FRC23 (1996-1999), Mentor FRC246 (2000), Mentor FRC1318 (2007-2009), Mentor FRC93 (2011), Mentor FRC2151 (2012), Mentor FRC23 (2013), Mentor FRC4761 (2014-2017)
1998 - National Chairman's Award and Woodie Flowers Award (FRC23, Mike Bastoni ) | 2007 - PNW SF (488, 1595) | 2008 - Oregon RCA - Seattle #2 Seed, SF (488, 1696) | 2009 - Oregon #1 Seed, Winners (1983, 2635) - Seattle SF (945, 2865) - Galileo #2 Seed, SF (973, 25) | 2012 Midwest F (111, 71) | 2014 RIDE Winners (78, 125), Inspector - NEU #24, QF (3479, 3958) - NECMP #35 | 2015 Reading #11, SF (1058, 190), Inspector - RIDE #17, QF(4055, 5494), Inspector - NECMP #57 | 2016 Reading #4, SF (133, 4474), DCA, Inspector - Ride #22, SF (1735, 2067), Creativity, Inspector - NECMP #48, RCA - Archimedes
Unread 18-03-2013, 21:31
bbuncher12 bbuncher12 is offline
FRC #0540 (Talon 540)
Team Role: Electrical
bbuncher12 is an unknown quantity at this point
We had a similar problem during several matches, where the cRio either rebooted or stopped responding for a while because the cpu usage maxed out. We will be doing more tests, but in our case it seems to be due to lots of sensors (Axis and NXT cameras, a repeating if->then loop with an ultrasonic).
Unread 19-03-2013, 07:36
CPU usage of 100% will not in itself cause a reboot or a crash. It can cause lag, but doesn't necessarily have to.
If the code has errors being printed to the Messages tab of the DS, then that adds quite a bit to the CPU load. Correct the errors first, as they may also explain other driving symptoms.
If the CPU usage still seems high, post code along with a description of how it behaves and we can help and can show tools that will help determine how fast various parts of the code are running.
Greg McKaskle
Unread 20-03-2013, 00:11
propionate's Avatar
propionate propionate is offline
Team co-lead and LabVIEW programmer
AKA: Stephen
FRC #1732 (Hilltopper Robotics)
propionate is on a distinguished road
We repeatedly get CPU usage errors from the code if we are calling Refnums in Periodic Tasks or Teleop that are not valid. Make sure every Refnum (the pink string that names a motor/solenoid/etc) you are calling is being properly set-up in Begin and is actually wired on the robot.
In addition, calling the same Refnum twice in periodic tasks has caused 100% CPU usage as well. Just my 2 cents
Unread 21-03-2013, 07:02
The refnum issues you mention would cause errors, and piping unhandled errors to the console is somewhat expensive. If you fix the errors, the CPU usage will drop dramatically.
Greg McKaskle
