Go to Post there's no time like week 5 to learn programming :D - dcarr [more]
Unread 18-03-2013, 22:52
Andrew Lobos Andrew Lobos is offline
FRC #0225 (TechFire)
Rookie Year: 2011
Andrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the rough
Re: Problem with driving
Did you notice the jerking when driving straight or only when turning? I'm not a mechanical person, but it really looks like your gearboxes contribute to your issues.
Feel free to correct me if I'm wrong on this:
- 6 inch wheels
- 4.67:1 reduction in CIMple gearboxes
- 1 CIM per gearbox
- 1:1 chain linkage to wheels
For this configuration, JVN design calculator says you have a max speed of 24.11 ft/sec and a maximum pushing force of 60.26lbs.
Also remember that the WPILib Scheduler calls your execute() methods on one thread - if one starts blocking it will affect other commands.
Unread 18-03-2013, 22:59
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
- 6 inch wheels
- 1 CIM per gearbox
It's dipping so low because you're simply stalling the motors when you even try to move.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016) | FTC Referee (2017)
Academic Student (Forever)
Unread 18-03-2013, 23:11
Rookie Year: 2011
I agree with CalTran.
In 2011, we did the same thing with 8 inch wheels (traction in back, omni in front) but with a reduction between the gearbox and the wheels (chain). The robot barely had enough torque to turn. We ended up switching the CIMple boxes with Toughboxes since we were using a third CIM somewhere else that year.
If you have 2 CIMs or MiniCIMs to spare, you should really put them in those CIMple gearboxes. Unless you have a need for the CIMple box speed, you might be better off switching to the kit toughboxes. Even then, I would still put two CIMs in, otherwise you'll just get pushed around by everyone else.
Unread 18-03-2013, 23:18
AsianRookie AsianRookie is offline
AKA: Steven/Tim
FRC #0321 (Robolancers)
Rookie Year: 2007
AsianRookie is an unknown quantity at this point
I think we are going to change the drive train if our weight permits it. I will get back to you guys within a day or three. Thanks for all your help though. By Lenepe, we are going to be awesome.
Unread 18-03-2013, 23:36
professorX professorX is offline
AKA: Xavier
FRC #1660 (The Harlem Knights)
professorX is an unknown quantity at this point
During the regional, we had a similar issue where our robot would work in the pit area but would "lag" when we drove it on the field. At first we thought it was a cpu issue and then we made the wait loops a little longer (tenth of a second i believe). That did not get rid of the issue.
We started jerking the robot back and forth in the pit to see if we could reproduce the issue. The light on the jaguars were turning from solid yellow to flashing yellow. We traced the problem back to the cRIO. Specifically, our ethernet cable was zip tied really tight and it would lose communication everytime we jerked the robot. Simply creating some breathing room for the ethernet cable solved our issue. Hopefully your problem is easy to solve as ours.
