Go to Post No one said that this would be easy. And if they did, they were obviously refering to a little red button from Staples and not to FIRST. - artdutra04 [more]
Unread 19-03-2013, 12:50
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
Rookie Year: 2011
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
Full court shooting strategy
Hi, all. We have our first regional coming up this weekend in Chandler, AZ.
The Bit Buckets have built a low profile, fast shooting, floor pickup bot that we have added an angled feed to the top of so that we can do full court shooting. (We withheld the shooter and put it on a wooden mule for post-build time-wasting.) We seem to be able to score ~90% in the 2 point goal and ~50% in the 3 point goal at 50 feet.
I assume that full court shooting is most likely to be useful to win qualification matches, since in those matches when there's no wallbots, we should be able to shoot all 51 frisbees in about 1:30.
Have any of you folks actually done full court shooting? What was your experience, in terms of actual success vs planned success, and when was it useful as an extra scoring strategy?
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 19-03-2013, 12:56
darkember darkember is offline
AKA: Billy
FRC #0375 (Robotic Plague)
Rookie Year: 2007
darkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of lightdarkember is a glorious beacon of light
Re: Full court shooting strategy
What we did was run cycles. Load 4 go to pyramid and score. We switched to full court shooting when we ran into either too much defense or when we wanted to avoid interfering with alliance partners who were also running cycles.
Unread 19-03-2013, 13:02
Jrat47's Avatar
Jrat47 Jrat47 is offline
AKA: Jerry R.
FRC #0051 (Wings Of Fire)
Jrat47 is an unknown quantity at this point
This strategy will be very effective in qualifying matches. In most cases a bombardment of 2 pointers should suffice but be prepared in the elimination matches to be blocked. You will draw a lot of attention to yourself being a long range shooter depending on who your partners are that may be exactly what you want to do. Let them shoot while the opposition focuses on trying to stop you.
hope this helps
"You Get Out of the Program What you Put into it" -Micheal Martus
Unread 19-03-2013, 13:11
John Sabath's Avatar
John Sabath John Sabath is offline
LabVIEW Software Developer
FRC #3792 (The Army Ants)
Rookie Year: 2012
John Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to beholdJohn Sabath is a splendid one to behold
hope this helps
Case in point: The St. Louis Regional and team 1706.
1706 plowed their way through qualifications (scoring 100+ points in almost every game they played in) and ended up on the 1st seeded alliance. However, they ended up losing in the finals due to 3284's defensive net completely shutting them down.
http://www.youtube.com/watch?v=iHik1lx5PLw
Freshman at Missouri S&T ( Computer Science )
FRC 3792 (The Army Ants) from 2012-2013
Unread 19-03-2013, 13:25
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Depending on the robot's exact configuration, Full Court Shooting is a viable and extremely effective strategy. In our last district event we were lucky enough to partner with 225 and their FCS. They were devastatingly accurate shooting into the 2pt goal and that combined with their high exit point (~50" or so) made them really, really tough to effectively defend. Most wall bots that were built on the fly to counter their shooter weren't all that effective.
That being said, if you've got a low FCS, say under 48" tall or so, odds are, someone will be able to block the better part of your shots. Though, it's worth noting, that the difference between a shot clearing a blocker and not is usually a matter of a few inches....
Unread 19-03-2013, 13:31
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Rookie Year: 2012
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
We were shooting full court sometimes at Traverse City (Week 1). It worked well, but beware teams blocking you. We saw many many teams adding poles to their robots to block us (and other full court shooters). Be prepared to deal with defensive robots. Hope this helps.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Unread 19-03-2013, 13:36
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
I think we'll see some excellent full-court strategies at MSC/MAR/Champs, where there will be more full-court shooters available. 2, or even 3 full court shooters that are also great at pyramid cycle runs could dominate one of the Divisions. Full-court shooters are especially useful if they can also drive underneath the opponents' pyramid for an end-around reverse (bot 3 comes underneath either bot 1 or bot 2, both of which leave their full-court shooting positions to run a cycle, thus taking defense with them; bot 3 then begins full-court shots).
It's an age-old remedy to a long-standing FRC defensive strategy of clogging up a field against great teams ('07, '10-'13): Fight them where they are not.
GitHub
Unread 19-03-2013, 14:14
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
In addition to being blocked once you start shooting, expect to be blocked on your journey to the protected feeder.
Work with your alliance partners on a good strategy to get you past the defense into the protected zone. For example, your partners can pin the opponents to the rail while you zip around the right side of the pyramid to the feeding zone. Or have a partner push you through the defense to get to the feeder zone.
You can expect to be blocked and slowed on your way there, so you will need to have help from your partners to get in the zone.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 19-03-2013, 15:38
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Team Role: Leadership
Rookie Year: 1998
Mr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond reputeMr. Lim has a reputation beyond repute
A lot of different variables at play here.
Assuming your pyramid cycling is pretty fast, and your setup time for full-court shooting slows things down, you just might be better off cycling shots at the pyramid. In this case, the threat of a full-court shot keeps the defence close to you at the feeder station, which makes it easier to drive past them through their pyramid when cycling.
You may not have the full-court shot very often as a low-profile robot. But sometimes you can take advantage of a defender who needs to go and hang early in the match.
http://www.youtube.com/watch?v=uNDNX...YdSlRb_rLXUTtM
As much as I like the full court shot, at BAE our cycling ended up being faster and more accurate.
http://www.youtube.com/watch?v=lvjdN...YdSlRb_rLXUTtM
Your mileage may vary of course... but my non-answer is to do what's going to score you the most points .
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 19-03-2013, 15:41
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
Rookie Year: 1998
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
This reminded me of 1519, Mechanical Mayhem at GSR in week 1.
They teamed up in the finals with 885, The Green Team, who had floor pickup.
As I have stated in other posts, a Full Court Shooter, combined with a floor pickup Robot, is the combination that I believe will take Einstein this year.
It eliminates midfield traffic, and the third bot can keep a defender away from an FCS.
Any disks that don't make it in the goal, can be picked up and scored.
1519 didn't win GSR, bout they did win North Carolina last weekend, so watch for them in St. Louis.
IMHO, If they were to be allied with a team like the Rocketeers (20), who have an excellent floor pickup and can use the pyramid for protection, they would be unbeatable.
Unread 19-03-2013, 15:45
Mr. Pockets's Avatar
Mr. Pockets Mr. Pockets is offline
Optimist Alumnus
AKA: Nathan
FRC #1189 (Gearheads)
Mr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond reputeMr. Pockets has a reputation beyond repute
This works phenomenally against rookie teams and for the first half of the competition or so. By that point, even at Detroit where a quarter of the teams were rookies, almost all bots had installed some form of wall to deal with the cross court menaces (though limited driving ability of some rookie teams rendered a lot of the walls limited in their effectiveness)
Year 1: Learned about Projects
Year 2: Learned about People
Year 3: Learned about Pride
Year 4: Learned about Promise
I came to robotics for the robot, but stayed for the people
2012/13 Melancholic retiree and wistful dreamer
Unread 19-03-2013, 15:48
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is offline
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen is a jewel in the roughWren Hensgen is a jewel in the roughWren Hensgen is a jewel in the rough
As part of 225, I have to agree that blocking is going to be an issue for us. We lost once in the semis, and once in the finals due to the heavy defense stopping our robot from ever reaching the feeder station. Metal Moose in particular played an awesome defense, relying on their powerful drive to shove us around the field.
Unread 19-03-2013, 16:00
NotaJoke's Avatar
NotaJoke NotaJoke is offline
Future Engineer
Team Role: Scout
Rookie Year: 2012
NotaJoke has much to be proud ofNotaJoke has much to be proud ofNotaJoke has much to be proud ofNotaJoke has much to be proud ofNotaJoke has much to be proud ofNotaJoke has much to be proud ofNotaJoke has much to be proud ofNotaJoke has much to be proud of
Full court shooting should work well during qualification matches, but it is not a viable primary method of scoring in eliminations, unless you have some way to shoot through or around defense (I'm looking at you, 225~). Any and every alliance will add a net (or pool noodle) to block you, and will be on you before you can fire your second disk.
It does, however, add an interesting secondary effect. If you should, for some reason, need the defensive robot to move closer to yours, shooting full court is a sure way to force them into blocking distance or closer.
Scout FIRST, ask questions later.
Unread 19-03-2013, 19:16
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Team Role: Coach
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
I have personally seen full-court shooting wreck havoc during qualification matches (1 robot scoring 100pts by themselves, another robot scoring 23 consecutive discs).
I have also personally seen those same full court shooters get shut down during the playoffs.
What I have yet to see is an alliance prepare for this ahead of time and draft a robot with the specific task in mind to stop the defender/mobile wall from blocking the cross-court shots. When alliances realizes that there is a legitimate way to prevent your cross-court shooter from being blocked, this game will get really interesting. For now, it's relatively predictable.
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2017: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
  #15   Spotlight this post!
Unread 19-03-2013, 19:33
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
I'm very surprised most teams aren't taking advantage of the 84 inch rule when making an "on the fly" wall bot.
Seems a bot with a wide appendage at 84 inches would block any shot.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
