Go to Post Start building your robot as soon as possible, but not sooner. - Richard Wallace [more]
Unread 19-03-2013, 15:25
eitanniv eitanniv is offline
FRC #3316 (D-bug)
Rookie Year: 2012
eitanniv is an unknown quantity at this point
swerve sketch
Hey! I'm from D-bug 3316 and I would like some help. I would like, for personal needs, a sketch of swerve wheels. I would like the sketch to have arrows showing how the wheel can turn.
Like the picture attached only... good...
Unread 19-03-2013, 15:29
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Re: swerve sketch
You can use Powerpoint to make decent graphics for things like this.
Delete everything on a slide, and use the Shapes tool in the Insert toolbar to draw various shapes and arrows.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 19-03-2013, 15:39
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Rookie Year: 2012
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Re: swerve sketch
Or, another option would be to go get Paint.net which is as easy to use as MS Paint but has layering and other Photoshop-esque features for free.
It's what I use for a lot of things.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 19-03-2013, 15:51
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Rookie Year: 2012
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
Re: swerve sketch
I also suggest Paint.net. Excellent program. Here's a link: http://www.getpaint.net/ Watch out though, be careful what download button you hit. The big green ones are ads. Hope this helps.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Unread 19-03-2013, 16:14
FRC #3316 (D-bug)
Rookie Year: 2012
Re: swerve sketch
the thing is im not a good sketcher and im not sure how to make a swerve wheel sketch.
Unread 19-03-2013, 17:02
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: swerve sketch
How bout this.
Name:	Module Assembly-1.jpg
Unread 19-03-2013, 22:17
DonRotolo's Avatar
Back to humble
FRC #0832
Re: swerve sketch
To explain that image above, the big sprocket on top is used to turn the whole module, while the shaft with the arrows is what is turned to make the wheel move (through some right-angle gears and, in this case, a chain). That shaft is co-axially mounted (on bearings) to the module, so the sprocket and the shaft spin independently from each other.
Unread 19-03-2013, 23:59
jspatz1's Avatar
AKA: Jeff
Rookie Year: 2007
Re: swerve sketch
Sorry to trick you Don. This is actually our motorized module from 2010 and is not a co-axial module. The top stem is a single fixed stem that mounts in a pivot bearing. The exterior chain is one of two chain steps from the motor pinion to the wheel sprocket. Perhaps I should have used this view instead:
Name:	Module Assembly-2.jpg
Unread 20-03-2013, 08:39
FRC #3316 (D-bug)
Rookie Year: 2012
Re: swerve sketch
thank you very much! that's exactly what i needed
Unread 20-03-2013, 10:32
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: swerve sketch
I too interpreted the drawing as showing the top post rotating along with the wheel. It's not obvious that the upper arrow belongs with the sprocket.
Unread 20-03-2013, 18:28
jspatz1's Avatar
AKA: Jeff
Rookie Year: 2007
Re: swerve sketch
Take 3.
