Go to Post quick everyone find everything in the whole world that sells for $125 so we can get an edge on our building 2 days before kick off.....ready...go! - Greg Needel [more]
Unread 19-03-2013, 23:46
mcvittal mcvittal is offline
FRC #3756
mcvittal has a spectacular aura aboutmcvittal has a spectacular aura about
Image rotation and the axis camera
Hey everyone!
I know that in Java you can only rotate the axis camera output 0 and 180 degrees, but I've read in forums that you can rotate the image output to many more angles using LabVIEW.
Because the driver station is written in LabVIEW it seems only logical that you should be able to access the angle change somehow through Java to manipulate camera output on the driver station.
Our mechanical team decided to mount the cam sideways this year, and I've found no way of just rotating the output image.
Any ideas on how to go about doing this?
Unread 19-03-2013, 23:54
nekojess nekojess is offline
Controls Surgeon and Diagnostician
AKA: Jessica C
nekojess is an unknown quantity at this point
Re: Image rotation and the axis camera
Check out the actual camera settings (by going to it in a web browser). You can actually rotate the image 90°, 180°, and 270° on the camera itself.
Unread 20-03-2013, 00:41
FRC #3756
I tried logging into the web browser but it required authentication, the username and password provided by FIRST to not seem to work.
Unread 20-03-2013, 11:11
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
Rookie Year: 2012
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Are you using an M1011 or M1013? The M1011 (at least, on the factory firmware) only gives options for 0 or 180.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 20-03-2013, 11:27
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
Rookie Year: 2010
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
default I believe is user: admin pass:admin
Unread 20-03-2013, 12:08
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Rookie Year: 1999
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
The USER and PASSWORD are case sensitive for FRC.
IIRC the Camera Setup Tool sets FRC and root as follows:
User: FRC
Pass: FRC
The other should be:
User:root
Pass:admin
See this document: http://wpilib.screenstepslive.com/s/...an-axis-camera
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
