Go to Post Just wanted to know some of your favorite physics and math equasions during build seasions thanks. mine is pathagriom therom - team 3311 [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:25
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Drive motors
Posted by David Kelly.
Student on team #234, Cyber Blue, from Perry Meridian H. S. and Rolls-Royce.
Posted on 11/11/2000 6:07 PM MST
I'm just curious. What are other teams using for their main drive motors? We have had problems with the keyang motors overheating. We are going to have to swich to drill motors. Other than that, we are about DONE! Praticing all week!!
Good Luck!
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Check your drivetrain
Posted by Jason Rukes.
Engineer on team #109, Arial Systems & Libertyville HS, from Libertyville High School and Arial Systems Corp & SEC Design.
Posted on 11/11/2000 9:14 PM MST
In Reply to: Drive motors posted by David Kelly on 11/11/2000 6:07 PM MST:
How long are you running the Keyangs before they overheat? You may be wasting a lot of power on friction in your drivetrain. Try this, disconnect your drive motors from the drivetrain. Lift your drive wheels off the ground and try spinning the wheels by hand. If you can't easily spin the wheels, then you've got a friction problem. Here are a few things to look out for:
1. Make sure your axles are aligned. Bent axles create a large amount of resistance.
2. If you are using bushings with shaft collars, make sure the shaft collars aren't rubbing against the bushings too tightly.
3. Your chain should have some slack in it. Don't try to over-tighten the chain by removing an extra link. Just use some PVC, a fender washer, and a bolt to make an idler.
More power to Ya!
-Jason
#0047 (ChiefDelphi)
Motors for driving
Posted by Nick .
Student on team #240, Mach V, from Jefferson Monroe High School and Visteon.
Posted on 11/12/2000 5:35 AM MST
I would highly advise against using the drill motors unless you want your robot to be pushed around all the time during the match, however it's your decision, not mine. We are using the keyangs and the globes in an interesting combination that is worth seeing the day of the competition. But be advised, if you try to replicate our drive train, it WILL be frustrating to get it to operate smoothly.
#0047 (ChiefDelphi)
Re: Motors for driving
Posted on 11/13/2000 8:05 AM MST
In Reply to: Motors for driving posted by Nick on 11/12/2000 5:35 AM MST:
Hmm... fast AND strong? You will be a worthy opponent, grasshoppa.
[IMG] code is Off
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
How many motors are you using to drive? Joseph F Motors 18 16-10-2002 21:24
Looking for practice motors & extra tape drive parts? archiver 2000 1 23-06-2002 22:54
Drill Motors TF8 Motors 19 12-12-2001 13:13
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
