Loading Zone - Max Height
What would be the max height a robot could be while in its loading zone?
I would assume 60" because you are outside of the team's autozone. |
Re: Loading Zone - Max Height
Correct.
If you're in the loading zone and still in contact with your pyramid or auto zone, you are WAY outside that 54" cylinder. |
Not sure what the 54 cylinder has to do with it.
Once no longer contacting your auto zone carpet you limited to 60". Your loading zone is a long ways from that. |
That's exactly his point. If you are somehow touching both the loading zone and your own auto zone/pyramid, you will have extended beyond the 54" cylinder.
If you are in your own loading zone you can extend to 84 inches
If I'm wrong, please cite the rule. |
While in yiur loading zone you can be a max a 60in. but if you are in your pyramid zone where your goals are you can go 84in.
There were some add-ons for G23 to address the cylinder relative to pyramid climbing, but the essence hasn't changed. |
