Go to Post Where we are is only of modest importance. And where we are going is what is really important. - ebarker [more]
Unread 21-03-2013, 11:24
azureflame241 azureflame241 is offline
FRC #3283
azureflame241 is an unknown quantity at this point
No Robot Code
The cRIO that were using is imaged in LabView and we have the code loaded onto the cRIO, we are able to connect to the cRIO but it says no robot code in the driver station, can some one help us with this problem?
Unread 21-03-2013, 11:57
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: No Robot Code
"No robot code" means that the Driver Station cannot communicate with a robot program running on the cRIO. If you are connected and the "Communication" indicator is green, then it means no code is running on the cRIO.
It can happen if no code was loaded before the system was booted. How did you load the code onto the cRIO?
It can also happen if code is present but the NO APP switch is turned on. If you are using an 8-slot cRIO with physical switches, make sure NO APP is OFF. If you have a 4-slot cRIO, use the imaging tool to make sure the virtual NO APP switch is off.
Unread 22-03-2013, 01:08
eruiz22 eruiz22 is offline
FRC #4210
eruiz22 is on a distinguished road
Re: No Robot Code
Hey my team had the same problem this year. I found that restarting the robot after building and deploying fixed our problem.
I think it's worth a try
Unread 22-03-2013, 09:39
Software Architect
Re: No Robot Code
If you use the Run As Startup command instead of Deploy, the robot will be rebooted as part of the process. There's never really a good reason to use the Deploy command in LabVIEW.
Unread 04-04-2013, 14:37
FRC #3283
Re: No Robot Code
We used LabView to load the code on the robot, we used Robot Main.vi to load on the cRIO
Unread 04-04-2013, 15:28
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: No Robot Code
Using robot main does not permanently place a copy of the compiled program onto the robot.
To do that, you need to use the project explorer, move to the bottom item "Build Specifications", and click the "+" symbol to expand it. Right click on the item that was revealed, then click "build". Once the build is complete, right click again and click "Run as startup". This will place your compiled code onto the cRIO so that it executes whenever the cRIO is powered on.
