Go to Post Let's see some love for these fine people. Let's give it up for the refs. - Andy Baker [more]
Unread 21-03-2013, 13:08
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
Rookie Year: 2011
fovea1959 will become famous soon enough
network tables and arrays
have a labview robot, want to write to it's network tables from a java app on driver station. That works great, but now I want to write an array of numbers.
If I write a array of numbers to the network table from labview, Java sees it as an Object[] containing Doubles. If I try to construct the same using
networkTable.putValue ("array", new Object[] { double1, double2 } );
I get an IllegalArgumentType: Invalid Type exception.
Is what I am attempting doable?
Unread 21-03-2013, 15:48
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Rookie Year: 2010
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: network tables and arrays
Here's the method that's throwing the exception (from edu.wpi.first.wpilibj.networktables2.NetworkTableN ode):
Code:
	public void putValue(String name, Object value) throws IllegalArgumentException{
            if(value instanceof Double){
                    putValue(name, DefaultEntryTypes.DOUBLE, value);
            } else if (value instanceof String){
                    putValue(name, DefaultEntryTypes.STRING, value);
            } else if(value instanceof Boolean){
                    putValue(name, DefaultEntryTypes.BOOLEAN, value);
            } else if(value instanceof ComplexData){
                    putValue(name, ((ComplexData)value).getType(), value);
            } else if(value==null) {
                throw new NullPointerException("Cannot put a null value into networktables");
            } else {
                throw new IllegalArgumentException("Invalid Type");
NetworkTables can only contain Doubles, Strings, Booleans, and ComplexData. ComplexData is implemented by ArrayData, which is extended by BooleanArray, StringArray, and NumberArray. I think you want to use NumberArray, and as far as I can tell, you'd use it like this:
Code:
NumberArray outputArray = new NumberArray();
outputArray.add(double1);
outputArray.add(double2);
networkTable.putValue("array",outputArray);
I code stuff.
Unread 29-03-2013, 10:42
fovea1959's Avatar
AKA: Doug Wegscheid
Rookie Year: 2011
That worked. Thanks!
