Go to Post John is the king of vague, but then again he looks much better at a distance than he does up close :D - Rich Kressly [more]
Unread 21-03-2013, 13:18
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
Rookie Year: 2012
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Switching from Toughbox to SuperShifter
I'm wondering if anyone who has experience with both can offer some insight, and some general drive-train advice.
My team would like to switch to a shifting gearbox, and I'm trying to weigh the feasibility of the task. From the images on andymark, the toughbox and supershifter look similar enough, however our robot is pretty tightly packed, and so any changes in the footprint of the shifter (dimensions, where the motor sticks out, etc) could be a deal breaker.
Also open to information on the Vex Ball Shifters.
Adding the pneumatics won't be a problem for us, and the programming portion is also fine; but from a mechanical standpoint, I don't want to throw down several hundred dollars only to find out they won't fit.
Gearing ratio suggestions are also appreciated (we're using 6" high grip wheels,4 wheel chain drive, with 1 cim each side), right now we're geared really low, and the kids love it, but the lack of speed when we need it is troublesome.
I've also considered gearing the robot up a bit and throwing another CIM in to help offset the gearing, will that give us more speed with the same push?
Unread 21-03-2013, 13:34
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Team Role: Teacher
Rookie Year: 2007
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: Switching from Toughbox to SuperShifter
For the last several years we have used Supershifters (each with 2 cims) and are currently looking at options for next year as our season is now over.
Why do you need the second gear ratio? Do you intend to drive in one ratio and use the other for a specific purpose? That is drive in "high" all the time and switch to low when you need more torque?
Alternatively if you just need to slow down your drivebase for specific maneuvering, like last year's bridge you can always implement software to limit speed.
Edit: Next year we are hoping to transition to a sheet metal drivebase and hope to better integrate our transmissions into our frame. We are currently looking at the WCP plates that use AndyMark internals but nothing solid at this point.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 21-03-2013, 13:36
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Rookie Year: 2012
Gregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond reputeGregor has a reputation beyond repute
Use 2 CIMs on each side, otherwise no point in a shifting gearbox.
What are nationals? Sounds like a fun American party, can we Canadians come?
“For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.” -Jean Dubuffet
"Insanity is doing the same thing over and over again and expecting different results." -Albert Einstein
FLL 2011-2015 Glen Ames Robotics-Student, Mentor
FRC 2012-2013 Team 907-Scouting Lead, Strategy Lead, Human Player, Driver
FRC 2014-2015 Team 1310-Mechanical, Electrical, Drive Captain
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 21-03-2013, 13:59
Programming Mentor
AKA: Joe S
Rookie Year: 2012
We want to be able to be fast while not losing our ability to win a pushing match.
If we get shifters, we will likely put the second set of CIMs on if we can spare the weight (or if we change gears in the toughbox). We are currently geared low (not sure how low, but we don't get pushed at all, and are pretty slow)
The general consensus seems to be gear up and add a CIM as an easy solution. However, I'm still interested in switching to shifters if it's possible to do on our robot (during an event), I'm looking for observations from someone who has made the switch; do the parts have the same attachment points/dimensions, are there any gotchas that we could run into, etc?
Unread 21-03-2013, 14:16
Shane 2429 Shane 2429 is offline
FRC #2429
Shane 2429 is infamous around these partsShane 2429 is infamous around these parts
In my personal opinion cut the weight out from somewhere else and put those extra motors into your gearboxes they are extremely helpful in a 1v1 or even 1v2 pushmatch and in cases like this year when the center of the field turns into a rugby scrum.
Unread 21-03-2013, 14:46
protoserge's Avatar
protoserge protoserge is online now
CAD, machining, circuits, fun!
AKA: Some call me... Tim?
FRC #0365 (MOE) & former 836 Mentor)
protoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond repute
I'd recommend "running what you've got". If you can get an extra CIM in there now, do it. Swapping gear boxes is not a trivial matter and may cause you to miss most of your practice matches (which you'd need to debug your new setup).
If you are confident enough in your ability to swap out the gear ratios, that may be beneficial as well. There are many teams running single speed gearboxes out there and are having a very successful season.
What are the strenths of your robot? What are the specs (dimensions and weight). Do you have a photo to help demonstrate the steps required for swapping the transmission out?
Unread 21-03-2013, 17:26
midway78224 midway78224 is offline
AKA: Rudy
FRC #5572 (Rosbots)
midway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to beholdmidway78224 is a splendid one to behold
Send a message via Yahoo to midway78224
Ive been running super shifters for a few yrs now. Our setup has always been to gear up the high gear where you run a 6:1 gear ratio. Then we run a 15:22 tooth sprocket from gearbox to wheel. We use the 6 inch first wheel. This give us about a 13.5 ft/sec in high and 4 ft in low. We have enough speed to do our gameplan and more then enough power to be in a pushing match. When we tested our low gear we pushed 325 lbs. If you have any more questions you can pm me and ill love to answer them.
[size="1"]
2004-2008 '11 457 Greasemonkeys
2012-2013 3997 Screaming Chickens
2014 3614 The Love Machine
2015-Present Rosbots
Unread 21-03-2013, 18:14
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
The output shafts come out a bit toward the corners on a SS. They come out the middle of the toughbox. Could cause some headaches swapping them. The ball shifters output is centered like a toughbox
Unread 21-03-2013, 18:17
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
Team Role: Mechanical
Rookie Year: 2011
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
If your TB's are chain driven, the regular shifter is probably a better option. The super shifter is geared for direct drive, or 1:1 chain.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
Unread 21-03-2013, 19:02
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Like others I really really really (that's three reallys on the really scale suggest against changing this late in the game. Find a way to get those two other motors on there, you will be surprised at the difference.
AM has many ratios available for the toughboxes so you can also gear a little faster and still have good pushing power with those extra motors. At the same time you can reduce weight by using AM's aluminum gears and trading the box housings for the spacers also offered at AM.
Unread 21-03-2013, 18:16
Chris is me's Avatar
Chris is me Chris is me is online now
AKA: Pinecone
By no means are shifters mandatory this year. If you want a competitive drive that can push alright and still drive quickly, 4 CIMs is mandatory before you even start talking about shifters.
I would go with that, and try shifters in the off season. You don't want to take such a huge risk with such an essential part of your robot without experience, or at least a CAD model
What is your current gear ratio, wheel size, and wheel material? I'd be happy to suggest an alternate drive ratio to give your team a starting point.
Unread 21-03-2013, 13:39
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
In general, the SuperShifter is intended to be used when wheels on your robot are direct driven by a live axle from the output of the gearbox. It sounds like you have a chain and sprocket reduction between the gearbox output and the driven wheels. This additional reduction could be why you feel that your robot is slow. We have the KOP tough box minis geared 10.7:1 direct driving 6" wheels to give us a speed of about 11 fps. To adjust the speed of your robot, you could also change out for smaller sprockets on the wheels or larger sprockets on the gearboxes.
I would definitely suggest adding 2 more CIMs to the drive train. This will increase available pushing power, increase acceleration, and reduce the amount of abuse the motors see. This alone will not increase your top end speed (maybe a very very small amount), but it will help you get there faster and could allow you to maintain your pushing force while doubling your speed through some other means (such as adjusting your gearing or sprocket reduction).
[2016-present] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 21-03-2013, 13:53
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
If you can't CAD the replacement, I'd recommend against it.
For a rough estimate of good speed vs torque, search CD-media's whitepapers for "JVN Calculator". Add 2 more CIM motors to the current gearboxes and figure out a better ratio for your drivers.
No matter what, realize that if you think you're fast -- there's always someone faster. If you think you can push -- someone else can push harder. Conform your design to your strategy, not to an errant edge condition. In other words: where on the field do you think extra speed would be useful EVERY match, and how much less agile will that make your robot in the cramped places on the field?
GitHub
