Go to Post work? I can't remember when the last time i did that was... - Carolyn Duncan [more]
Unread 23-03-2013, 09:24
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Team Role: Leadership
Rookie Year: 2012
Toa Circuit is an unknown quantity at this point
VT100 escape sequences or up a line on NetConsole
Does the NetConsole support VT100 escape sequences, or is there any other way for me to go up a line in it? Here is the code I want to use:
Code:
cout << "\x1b[A";
So that I can overwrite previous buffer stuff.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 25-03-2013, 03:23
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Rookie Year: 1997
jhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond reputejhersh has a reputation beyond repute
Re: VT100 escape sequences or up a line on NetConsole
Code:
cout << "\x1b[A";
I don't believe the NetConsole client supports that escape sequence, but trying it would be your best bet.
Unread 25-03-2013, 10:50
Thaddeus Maximus
AKA: Thad Hughes
Rookie Year: 2012
Our robot is in the bag... would it be possible for someone to test if it works?
Webpage
Unread 04-04-2013, 23:59
nightpool's Avatar
nightpool nightpool is offline
robotRectifier
AKA: Evan
no team (formerly of CORE 2062)
Rookie Year: 2011
nightpool is on a distinguished road
I'm going to (without testing) give you a pretty solid "no dice". The NetConsole is pretty limited in what it supports. There are a few replacements out there, but if you're looking to update things frequently (what I inferred from your question) you're probably better off in the long run learning and using the smart dashboard.
Smart Dashboard calls are pretty easy to drop in, here are some common conversions:
For numbers, replace
Code:
 cout <<  "Value: " << number_val << endl; // Substitute printf's to taste
with
Code:
 SmartDashboard::PutNumber('Value', number_val);
For booleans:
Code:
 cout << is_running ? "Motor is running" : "No motor running" << endl;
with
Code:
 SmartDashboard::PutBoolean("motor running", is_running);
Of course, don't take my word for it, always check the docs, for example the copy hosted here: http://www.virtualroadside.com/WPILi...dashboard.html or the one that came with your WPILib installation (at C:\WindRiver\docs\extensions\frc\WPILib C++ Reference.chm).
Proud alum of CORE 2062.
www.core2062.com
