Go to Post Paul Copioli - A guy who is 13 years older than me, but acts about 13 years younger. - Amanda Morrison [more]
Unread 23-03-2013, 20:03
ykarkason ykarkason is offline
21st Century Schizoid Man
FRC #3316 (D-Bug)
Team Role: CAD
Rookie Year: 2013
ykarkason will become famous soon enoughykarkason will become famous soon enough
Robot Code Deplyoment
Hi,
I just want to make sure I'm not making some silly mistakes;
Our team is at stages of switching programming languages(as it seems from LabView to Java).
I'm used from LabView to run the code - and at the end of the season to build it and deploy as a startup program.
Now, in Java with Netbeans - when I run the code it seems to deploy it as a startup program(by the way, wow! that's a heck faster then Labview) and that's it.
It seems logical that the cRIO's flash memory is somewhat limited, and using it and reusing it will eventually kill it, so... is it the correct behavior?
Thanks
Unread 23-03-2013, 20:47
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
Rookie Year: 2012
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
Re: Robot Code Deplyoment
Could you clarify your question?
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
Unread 23-03-2013, 22:15
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
Flash memory is rated for a number (usually in the 10,000s) of write cycles before the memory might fail. Sounds like the OP is asking if there's a way to run Java code on the cRIO without writing to the flash memory to extend the life of the cRIO.
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
Unread 24-03-2013, 02:57
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
Rookie Year: 2012
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
I think OP is asking whether Java is supposed to deploy and run on startup while LabVIEW just runs from memory. And the answer to this question (at least the first part, I'm not familiar with LabVIEW) is yes.
I wouldn't worry about the flash memory. To start with, your robot program isn't going to take up much space at all on the flash memory and most flash-using electronics implement some sort of wear-levelling, so you aren't writing to the same flash cells over and over. And even if you were (which again, you're not), 10,000 writes is the equivalent of deploying to the cRIO 10 times a day every single day for almost 3 years. And even then it would still be usable because that's a low estimate.
SSDs have been used in computers for years and see orders of magnitude more writes than the cRIO ever will. It shouldn't be a concern.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 24-03-2013, 08:45
FRC #3316 (D-Bug)
Team Role: CAD
Rookie Year: 2013
Ok, So that part is fine!
Awesome, so I don't have to worry.
Thanks guys!
