Go to Post Values aren't really dictated, they are created by everyone involved. - Herodotus [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:26
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Sprockets and Crimp connectors
Posted by Jason Rukes.
Engineer on team #109, Arial Systems & Libertyville HS, from Libertyville High School and Arial Systems Corp & SEC Design.
Posted on 11/15/2000 1:21 PM MST
1. In the App Notes section about Wheels, Wheels, Wheels, you state: Use a sprocket for a wheel (but remember that uncovered sprockets are not legal so you will have to cover the teeth with something – perhaps plain old chain. Is it legal to use an uncovered sprocket as a roller to collect a ball, as long as the roller will never touch the carpet? I'm assuming the reason that uncovered sprockets are illegal is to prevent damage to the floor.
2. Can we use the supplied crimp connectors as mechanical stops by crimping them on the end of a cable?
Thanks again,
Jason
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
#0047 (ChiefDelphi)
Q&A: Sprockets and Crimp connectors
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems.
Posted on 11/15/2000 2:48 PM MST
In Reply to: Sprockets and Crimp connectors posted by Jason Rukes on 11/15/2000 1:21 PM MST:
Question:
Answer:
This is fine, assuming that you don't damage the balls or rack either. We only have a limited number of spare balls. If you start hurting them, you will be forced to change your machine design.
Question:
Answer:
Perfectly legal.
[IMG] code is Off
