Go to Post However, in the end, the renderer is only as good as the artist. - MiNT [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 24-06-2002, 00:27
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
archiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond reputearchiver has a reputation beyond repute
Q & A Cotter Pins
Posted by Michael Martus.   [PICTURE: SAME | NEW | HELP]
Coach on team #47, Chief Delphi, from Pontiac Central H.S. and Delphi Automotives Systems.
Posted on 11/16/2000 6:39 PM MST
A question was asked by phone:
Question:
Is it OK to use cotter pins?
Answer:
A cotter pin is a fastner as long as it is used as a fastner.
Warning: Remember that a cotter pin is very soft and has only a small amount of shear strength. Using it to drive a wheel is asking for failure. Be careful in application.
This message was archived from an earlier forum system. Some information may have been left out. Start new discussion in the current forums, and refer back to these threads when necessary.
[IMG] code is Off
pic: Pins Pins and more pins CD47-Bot Extra Discussion 26 04-09-2005 23:07
Drill Motors: Pins IN or Pins OUT Caleb Fulton Motors 28 03-02-2003 14:19
dowel pins BBFIRSTCHICK Technical Discussion 10 27-01-2003 11:35
how do you hold pins in? archiver 2001 4 23-06-2002 23:45
drill pins Greg Needel Technical Discussion 2 10-02-2002 19:50
