Go to Post Removing too much of the challenge removes too much of the accomplishment when you solve the problem. Removing too much of the challenge removes too much of the innovation in the solutions... removing too much of the challenge removes too much of the fun. - dlavery [more]
Unread 03-26-2013, 09:51 AM
omsahmad's Avatar
omsahmad omsahmad is offline
FRC #1595 (Dragons)
Rookie Year: 2011
omsahmad is just really niceomsahmad is just really niceomsahmad is just really niceomsahmad is just really niceomsahmad is just really nice
Working on Example Camera Code
Hello, I am trying to simply get the camera to feed me data, from the example code, but I have some questions. When I run it using the image flashed in the cRIO, it works well (I guess, as in I get constant data). However when I try to use the GetImage from the axis camera it no longer feeds data. I used a utility to get the HSV from my camera, but that did not help, in fact it made it worse. Does the code look right?
Also what do these lines do? I understand that they write images to the cRIO after throughout the image processing, but in what cases would I want to use them. Apparently do this is bad for the cRIO as well?
Code:
BinaryImage *thresholdImage = image->ThresholdHSV(threshold);	// get just the green target pixels
//thresholdImage->Write("/threshold.bmp");
BinaryImage *convexHullImage = thresholdImage->ConvexHull(false);  // fill in partial and full rectangles
//convexHullImage->Write("/ConvexHull.bmp");
BinaryImage *filteredImage = convexHullImage->ParticleFilter(criteria, 1);	//Remove small particles
//filteredImage->Write("Filtered.bmp");
Code:
#include "WPILib.h"
#include "Vision/RGBImage.h"
#include "Vision/BinaryImage.h"
#include "Math.h"
 * Sample program to use NIVision to find rectangles in the scene that are illuminated
 * by a LED ring light (similar to the model from FIRSTChoice). The camera sensitivity
 * is set very low so as to only show light sources and remove any distracting parts
 * of the image.
 * The CriteriaCollection is the set of criteria that is used to filter the set of
 * rectangles that are detected. In this example we're looking for rectangles with
 * a minimum width of 30 pixels and maximum of 400 pixels.
 * The algorithm first does a color threshold operation that only takes objects in the
 * scene that have a bright green color component. Then a convex hull operation fills
 * all the rectangle outlines (even the partially occluded ones). Then a small object filter
 * removes small particles that might be caused by green reflection scattered from other
 * parts of the scene. Finally all particles are scored on rectangularity, aspect ratio,
 * and hollowness to determine if they match the target.
 * Look in the VisionImages directory inside the project that is created for the sample
 * images as well as the NI Vision Assistant file that contains the vision command
 * chain (open it with the Vision Assistant)
//Camera constants used for distance calculation
#define X_IMAGE_RES 320		//X Image resolution in pixels, should be 160, 320 or 640
//#define VIEW_ANGLE 48		//Axis 206 camera
#define VIEW_ANGLE 43.5  //Axis M1011 camera
#define PI 3.141592653
//Score limits used for target identification
#define RECTANGULARITY_LIMIT 60
#define ASPECT_RATIO_LIMIT 75
#define X_EDGE_LIMIT 40
#define Y_EDGE_LIMIT 60
//Minimum area of particles to be considered
#define AREA_MINIMUM 500
//Edge profile constants used for hollowness score calculation
#define XMAXSIZE 24
#define XMINSIZE 24
#define YMAXSIZE 24
#define YMINSIZE 48
const double xMax[XMAXSIZE] = {1, 1, 1, 1, .5, .5, .5, .5, .5, .5, .5, .5, .5, .5, .5, .5, .5, .5, .5, .5, 1, 1, 1, 1};
const double xMin[XMINSIZE] = {.4, .6, .1, .1, .1, .1, .1, .1, .1, .1, .1, .1, .1, .1, .1, .1, .1, .1, .1, .1, .1, .1, 0.6, 0};
const double yMax[YMAXSIZE] = {1, 1, 1, 1, .5, .5, .5, .5, .5, .5, .5, .5, .5, .5, .5, .5, .5, .5, .5, .5, 1, 1, 1, 1};
const double yMin[YMINSIZE] = {.4, .6, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05,
								.05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05, .05,
								.05, .05, .6, 0};
class RobotDemo : public SimpleRobot
	//Structure to represent the scores for the various tests used for target identification
	struct Scores {
		double rectangularity;
		double aspectRatioInner;
		double aspectRatioOuter;
		double xEdge;
		double yEdge;
//	RobotDrive myRobot; // robot drive system
//	Joystick stick; // only joystick
	Scores *scores;
	DriverStationLCD *lcd;
	SmartDashboard *sds;
	Jaguar *FRmotor; 			// Front Right motor,	ID: 1
	Jaguar *FLmotor; 			// Front Right motor,	ID: 2
	Jaguar *RRmotor; 			// Front Right motor,	ID: 3
	Jaguar *RLmotor; 			// Front Right motor,	ID: 4
	RobotDrive *drive;
public:
	RobotDemo(void)
		lcd = DriverStationLCD::GetInstance();
		FRmotor = new Jaguar(1); //(10);
		FLmotor = new Jaguar(2); //(13);
		RRmotor = new Jaguar(3); //(32);
		RLmotor = new Jaguar(4); //(31);
		drive = new RobotDrive(FLmotor, RLmotor, FRmotor, RRmotor);
		drive->SetInvertedMotor(RobotDrive::kFrontRightMotor, true);
		drive->SetInvertedMotor(RobotDrive::kFrontLeftMotor, false);
		drive->SetInvertedMotor(RobotDrive::kRearRightMotor, true);
		drive->SetInvertedMotor(RobotDrive::kRearLeftMotor, false);
		drive->SetExpiration(15);
// Motor Safety Enabled
		FRmotor->SetExpiration(0.1);
		FRmotor->SetSafetyEnabled(true);
		FLmotor->SetExpiration(0.1);
		FLmotor->SetSafetyEnabled(true);
		RRmotor->SetExpiration(0.1);
		RRmotor->SetSafetyEnabled(true);
		RLmotor->SetExpiration(0.1);
		RLmotor->SetSafetyEnabled(true);
	void Autonomous(void)
		Threshold threshold(60, 100, 90, 255, 20, 255);	//HSV threshold criteria, ranges are in that order ie. Hue is 60-100
//		Threshold threshold(80, 140, 0, 228, 15, 150);	//HSV threshold criteria, ranges are in that order ie. Hue is 60-100
		ParticleFilterCriteria2 criteria[] = {
				{IMAQ_MT_AREA, AREA_MINIMUM, 65535, false, false}
		};												//Particle filter criteria, used to filter out small particles
		while (IsAutonomous() && IsEnabled()) {
			lcd->Clear();
             * Do the image capture with the camera and apply the algorithm described above. This
             * sample will either get images from the camera or from an image file stored in the top
             * level directory in the flash memory on the cRIO. The file name in this case is "testImage.jpg"
			AxisCamera &camera = AxisCamera::GetInstance("10.15.95.11");	//To use the Axis camera uncomment this line
			ColorImage *image;
			camera.GetImage(image);	//To get the images from the camera comment the line above and uncomment this one
			camera.WriteResolution(AxisCamera::kResolution_320x240);
			camera.WriteWhiteBalance(AxisCamera::kWhiteBalance_FixedOutdoor1);
	//		image = new RGBImage("/HybridLine_SmallGreen3.jpg");		// get the sample image from the cRIO flash
			printf("Width: %dx", image->GetWidth());
			printf("Height: %d", image->GetHeight());
			vector<ParticleAnalysisReport> *reports = filteredImage->GetOrderedParticleAnalysisReports();  //get a particle analysis report for each particle
			scores = new Scores[reports->size()];
			//Iterate through each particle, scoring it and determining whether it is a target or not
			for (unsigned i = 0; i < reports->size(); i++) {
				ParticleAnalysisReport *report = &(reports->at(i));
				scores[i].rectangularity = scoreRectangularity(report);
				scores[i].aspectRatioOuter = scoreAspectRatio(filteredImage, report, true);
				scores[i].aspectRatioInner = scoreAspectRatio(filteredImage, report, false);
				scores[i].xEdge = scoreXEdge(thresholdImage, report);
				scores[i].yEdge = scoreYEdge(thresholdImage, report);
				if(scoreCompare(scores[i], false))
					lcd->Printf(DriverStationLCD::kUser_Line1, 1, "%dHi:%f Y:%f\n", i, report->center_mass_x_normalized, report->center_mass_y_normalized);
					lcd->Printf(DriverStationLCD::kUser_Line2, 1, "Dist: %f \n", computeDistance(thresholdImage, report, false));
					sds->PutNumber("Hi particle:", i);
					sds->PutNumber("Hi center X:", report->center_mass_x_normalized);
					sds->PutNumber("Hi Dist:", computeDistance(thresholdImage, report, false));
					printf("particle: %d  is a High Goal  centerX: %f  centerY: %f \n", i, report->center_mass_x_normalized, report->center_mass_y_normalized);
					printf("Distance: %f \n", computeDistance(thresholdImage, report, false));
				} else if (scoreCompare(scores[i], true)) {
					lcd->Printf(DriverStationLCD::kUser_Line1, 1, "particle: %d  is a Middle Goal  centerX: %f  centerY: %f \n", i, report->center_mass_x_normalized, report->center_mass_y_normalized);
					lcd->Printf(DriverStationLCD::kUser_Line2, 1, "Distance: %f \n", computeDistance(thresholdImage, report, true));
					sds->PutNumber("Mid particle:", i);
					sds->PutNumber("Mid center X:", report->center_mass_x_normalized);
					sds->PutNumber("Mid Dist:", computeDistance(thresholdImage, report, false));
					printf("particle: %d  is a Middle Goal  centerX: %f  centerY: %f \n", i, report->center_mass_x_normalized, report->center_mass_y_normalized);
					printf("Distance: %f \n", computeDistance(thresholdImage, report, true));
				} else {
					lcd->Printf(DriverStationLCD::kUser_Line1, 1, "particle: %d  is not a goal  centerX: %f  centerY: %f \n", i, report->center_mass_x_normalized, report->center_mass_y_normalized);
					printf("particle: %d  is not a goal  centerX: %f  centerY: %f \n", i, report->center_mass_x_normalized, report->center_mass_y_normalized);
				lcd->Printf(DriverStationLCD::kUser_Line3,1, "r%fAR%f \n", scores[i].rectangularity, scores[i].aspectRatioInner);
				lcd->Printf(DriverStationLCD::kUser_Line4,1, "AR%fx%fy%f  \n", scores[i].aspectRatioOuter, scores[i].xEdge, scores[i].yEdge);
				sds->PutNumber("rect:", scores[i].rectangularity);
				printf("rect: %f  ARinner: %f \n", scores[i].rectangularity, scores[i].aspectRatioInner);
				printf("ARouter: %f  xEdge: %f  yEdge: %f  \n", scores[i].aspectRatioOuter, scores[i].xEdge, scores[i].yEdge);
			lcd->UpdateLCD();
			printf("\n");
			// be sure to delete images after using them
			delete filteredImage;
			delete convexHullImage;
			delete thresholdImage;
			delete image;
			//delete allocated reports and Scores objects also
			delete scores;
			delete reports;
	 * Runs the motors with arcade steering.
	void OperatorControl(void)
		while (IsOperatorControl())
			Wait(0.005);				// wait for a motor update time
	 * Computes the estimated distance to a target using the height of the particle in the image. For more information and graphics
	 * showing the math behind this approach see the Vision Processing section of the ScreenStepsLive documentation.
	 * @param image The image to use for measuring the particle estimated rectangle
	 * @param report The Particle Analysis Report for the particle
	 * @param outer True if the particle should be treated as an outer target, false to treat it as a center target
	 * @return The estimated distance to the target in Inches.
	double computeDistance (BinaryImage *image, ParticleAnalysisReport *report, bool outer) {
		double rectShort, height;
		int targetHeight;
		imaqMeasureParticle(image->GetImaqImage(), report->particleIndex, 0, IMAQ_MT_EQUIVALENT_RECT_SHORT_SIDE, &rectShort);
		//using the smaller of the estimated rectangle short side and the bounding rectangle height results in better performance
		//on skewed rectangles
		height = min(report->boundingRect.height, rectShort);
		targetHeight = outer ? 29 : 21;
		return X_IMAGE_RES * targetHeight / (height * 12 * 2 * tan(VIEW_ANGLE*PI/(180*2)));
	 * Computes a score (0-100) comparing the aspect ratio to the ideal aspect ratio for the target. This method uses
	 * the equivalent rectangle sides to determine aspect ratio as it performs better as the target gets skewed by moving
	 * to the left or right. The equivalent rectangle is the rectangle with sides x and y where particle area= x*y
	 * and particle perimeter= 2x+2y
	 * @param image The image containing the particle to score, needed to perform additional measurements
	 * @param report The Particle Analysis Report for the particle, used for the width, height, and particle number
	 * @param outer	Indicates whether the particle aspect ratio should be compared to the ratio for the inner target or the outer
	 * @return The aspect ratio score (0-100)
	double scoreAspectRatio(BinaryImage *image, ParticleAnalysisReport *report, bool outer){
		double rectLong, rectShort, idealAspectRatio, aspectRatio;
		idealAspectRatio = outer ? (62/29) : (62/20);	//Dimensions of goal opening + 4 inches on all 4 sides for reflective tape
		imaqMeasureParticle(image->GetImaqImage(), report->particleIndex, 0, IMAQ_MT_EQUIVALENT_RECT_LONG_SIDE, &rectLong);
		//Divide width by height to measure aspect ratio
		if(report->boundingRect.width > report->boundingRect.height){
			//particle is wider than it is tall, divide long by short
			aspectRatio = 100*(1-fabs((1-((rectLong/rectShort)/idealAspectRatio))));
		} else {
			//particle is taller than it is wide, divide short by long
			aspectRatio = 100*(1-fabs((1-((rectShort/rectLong)/idealAspectRatio))));
		return (max(0, min(aspectRatio, 100)));		//force to be in range 0-100
	 * Compares scores to defined limits and returns true if the particle appears to be a target
	 * @param scores The structure containing the scores to compare
	 * @return True if the particle meets all limits, false otherwise
	bool scoreCompare(Scores scores, bool outer){
		bool isTarget = true;
		isTarget &= scores.rectangularity > RECTANGULARITY_LIMIT;
		if(outer){
			isTarget &= scores.aspectRatioOuter > ASPECT_RATIO_LIMIT;
		} else {
			isTarget &= scores.aspectRatioInner > ASPECT_RATIO_LIMIT;
		isTarget &= scores.xEdge > X_EDGE_LIMIT;
		isTarget &= scores.yEdge > Y_EDGE_LIMIT;
		return isTarget;
	 * Computes a score (0-100) estimating how rectangular the particle is by comparing the area of the particle
	 * to the area of the bounding box surrounding it. A perfect rectangle would cover the entire bounding box.
	 * @param report The Particle Analysis Report for the particle to score
	 * @return The rectangularity score (0-100)
	double scoreRectangularity(ParticleAnalysisReport *report){
		if(report->boundingRect.width*report->boundingRect.height !=0){
			return 100*report->particleArea/(report->boundingRect.width*report->boundingRect.height);
		} else {
			return 0;
	 * Computes a score based on the match between a template profile and the particle profile in the X direction. This method uses the
	 * the column averages and the profile defined at the top of the sample to look for the solid vertical edges with
	 * a hollow center.
	 * @param image The image to use, should be the image before the convex hull is performed
	 * @return The X Edge Score (0-100)
	double scoreXEdge(BinaryImage *image, ParticleAnalysisReport *report){
		double total = 0;
		LinearAverages *averages = imaqLinearAverages2(image->GetImaqImage(), IMAQ_COLUMN_AVERAGES, report->boundingRect);
		for(int i=0; i < (averages->columnCount); i++){
			if(xMin[i*(XMINSIZE-1)/averages->columnCount] < averages->columnAverages[i]
			   && averages->columnAverages[i] < xMax[i*(XMAXSIZE-1)/averages->columnCount]){
				total++;
		total = 100*total/(averages->columnCount);		//convert to score 0-100
		imaqDispose(averages);							//let IMAQ dispose of the averages struct
		return total;
	 * Computes a score based on the match between a template profile and the particle profile in the Y direction. This method uses the
	 * the row averages and the profile defined at the top of the sample to look for the solid horizontal edges with
	 * a hollow center
	 * @return The Y Edge score (0-100)
	double scoreYEdge(BinaryImage *image, ParticleAnalysisReport *report){
		double total = 0;
		LinearAverages *averages = imaqLinearAverages2(image->GetImaqImage(), IMAQ_ROW_AVERAGES, report->boundingRect);
		for(int i=0; i < (averages->rowCount); i++){
			if(yMin[i*(YMINSIZE-1)/averages->rowCount] < averages->rowAverages[i]
			   && averages->rowAverages[i] < yMax[i*(YMAXSIZE-1)/averages->rowCount]){
				total++;
		total = 100*total/(averages->rowCount);		//convert to score 0-100
		return total;
START_ROBOT_CLASS(RobotDemo);
Thanks!
