Go to Post And then since this is GTR-W there's also maple syrup somewhere and the drive team says "Sooory." - PayneTrain [more]
Unread 26-03-2013, 10:14
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
Rookie Year: 2011
fovea1959 will become famous soon enough
Updating the Dashboard
probably moving from LV to Java for 2014, starting to think about how we did some things in LV, and what the corresponding analogs in Java would be. Can't start slinging code for a while, no cRIOs to practice with (all are on bots), so asking questions right now instead of trying.
If one has put together a command based Java robot, and one wants to have continuous updates in the dashboard of critical sensors, is creating and scheduling a TimerTask to do the updates a good practice? I'm looking at Frog Force' 2013 code:
Code:
    private static final TimerTask SpeedTask = new TimerTask(){
        public void run() {
            if(isOn()&& DriverStation.getInstance().isEnabled()){
                SmartDashboard.putNumber("Shooter Output", output);
                SmartDashboard.putNumber("gear tooth speed graph", speed);
                SmartDashboard.putNumber("gear tooth speed view", speed);
    private static final long SPEED_TASK_PERIOD = 60;
    private static final Timer timer = new Timer();
    static{
        timer.schedule(SpeedTask, 0, SPEED_TASK_PERIOD);
Are there alternative practices?
Unread 26-03-2013, 15:20
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Rookie Year: 2010
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: Updating the Dashboard
We actually use a Command to update values to the dashboard, which, if you're calling Scheduler.getInstance().run() in both Periodic() methods, has the same effect as that TimerTask (though a different frequency). I have considered changing it to something that will send data regardless of whether the robot is enabled, but I'm loathe to change working code any more than I have to. Maybe next year.
I code stuff.
Unread 26-03-2013, 15:49
Bryce Paputa's Avatar
Bryce Paputa Bryce Paputa is offline
FF TSL: Frog Farce
FRC #0503 (Frog Force)
Bryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond reputeBryce Paputa has a reputation beyond repute
We used the timer task so we could change the frame rate of the speed control without effecting everything else, for most of the sensor stuff we either put it where the sensor was being used, or in the main file's teleopPeriodic. Either way works, however, putting them in teleopPeriodic is probably a bit more organized.
Unread 26-03-2013, 21:17
shindigo shindigo is offline
AKA: Mike Parker
FRC #0102
shindigo is an unknown quantity at this point
We're very interested in this:
Any advice on an approach to this?
Unread 26-03-2013, 22:11
Ginto8's Avatar
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Rookie Year: 2010
Well, NetworkTables, SmartDashboard and sensors don't depend on the robot being enabled; as far as I know, the only things hardware-wise that are really disabled by disabled mode are PWMs (and possibly normal digital outputs, but I have only know PWMs for certain). So if you have a TimerTask like in the original post, but remove the condition checking for an on/enabled state, it should continue sending data even in disabled mode.
I code stuff.
Unread 26-03-2013, 22:56
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
If you call the setRunWhileDisabled method for your command and add the scheduler run to disabledPeriodic, you can run your command while disabled with minimal code changes.
Unread 26-03-2013, 23:17
Ginto8's Avatar
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Rookie Year: 2010
I didn't even realize this functionality existed. That's pretty awesome.
I code stuff.
