Perhaps open up one tiebreaker match. If no team has two wins by the third match the team with more wins takes the set. If the number of wins is equal play a fourth match. If the fourth match is a tie use the tiebreakers. It allows for a tiebreaker match without the possibility of dragging things out forever.
Re: FRC Blogged - Doing the Right Thing
I might be alone here but I think after what happened it's only fair to let both alliances go to Championship. Yes, one alliance didn't win, but to be given something, and then taking it back just seems wrong. ~400 teams will go to Championship. This is a rare mistake. What's 3 more teams?
EDIT: 1,000th Post Last edited by Justin Montois : 27-03-2013 at 01:55. |
I mean that the same mistake could've been made and missed at any of those events.
Yeah absolutely. But since it was made at this event, I feel "Doing the right thing" would have been to allow the losing alliance to go on to Championship.
Given the circumstances, they rightly chose change the call and decide the winner based on gameplay. (If they'd discovered it too late—like as the field was being packed up, after the awards—then it might be a different story.) Last edited by Tristan Lall : 27-03-2013 at 02:45. |
The same mistake happened in Israel, they had to go back to quarter finals after the semi finals started..
Something should be changed with the tie breaker system if the field crew are doing the same mistake... |
#10
While I'm okay with the resolution, I agree with Justin that allowing the losing alliance to go to Championship would have been the best possible call.
#11
In this case, the scoring error occurred after the match was played. The Red Alliance clearly won the match, but a scoring error gave the win to the other team. It's entirely clear who the correct winner of the tournament was. And hey, look! After the error was corrected, the Red Alliance was the winner. For the record, I'm also against the "Everybody wins" solution. I understand the argument that the Blue Alliance was hurt and disappointed to discover that they didn't win after all, I just don't think it's valid. It's only slightly different from the more common scenario where they Blue Alliance thinks they've scored enough points to pull off the win, only to lose by 2 points because something. The only difference is a few more minutes of the Blue Alliance thinking it's won. Are you people really arguing that we should give people passes to Champs because they're disappointed and totally thought they should have won the competition? |
#13
I believe the point being made here is not that the blue alliance "thought they had scored enough points" or thought that they should have won. It was the fact that it was announced to everyone in attendance that the blue alliance had won the regional, and the correction to the score did not come until 15 minutes later. While some alliances may think that they'd won a match, and therefore the regional, this was not just an assumption the teams had made - they were told that they had won. I believe that is why people are arguing that the alliance should be given a pass to Championship, because they were officially told that they had earned one and later had it taken away. I also want to echo Frank in saying thank you to the volunteers at this event for coming forward and revealing what happened. I know how hard it must have been given the circumstances, but it was definitely the right thing to do. Thank you, and I hope that you continue to work with FIRST in the future. Please know that I am not trying to argue in favor of anything, given my association with the situation. I just wanted to attempt to clarify what is being said in this thread. |
#14
