Go to Post When I had "shop" back in High School they emphazied safety to the fullest extreme. I'm glad they did, I still have a full set of 7 fingers........ - Stillen [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 03-27-2013, 05:31 PM
Thad House Thad House is offline
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
CADing a baseplate
I have been working on CADing a few chassis, and I was wondering how do people actually make the diamond extrusions in the CAD. I cannot find a way to do it that doesnt take hours of work, and I am sure there is a better way.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 03-27-2013, 05:35 PM
pwnageNick's Avatar
pwnageNick pwnageNick is offline
It's like yeeee ho
AKA: Nick Coussens
FRC #2451 (PWNAGE)
Rookie Year: 2007
pwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond reputepwnageNick has a reputation beyond repute
Re: CADing a baseplate
You should use a sketch pattern. If you are using SolidWorks, when making the sketch, after you draw a diamond click the linear pattern button under the sketch tab. From there you just have to tell it what directions and how many patterns in those directions.
Inventor is very similar.
Both SolidWorks and Inventor should tutorials online on how to do this.
-Nick
FRC 2451: PWNAGE, Student/Team President (2009-2012)
FRC/VEX 2451: PWNAGE, Strategy/Design Mentor (2013-)
VEXU NAR: North American Robotics, Student/Chapter President (2013-)
Unread 03-27-2013, 05:39 PM
HammadB's Avatar
HammadB HammadB is offline
FRC #0295 (Renevatio)
Rookie Year: 2007
HammadB will become famous soon enough
What CAD software are you using? If it is SolidWorks then I can send you CAD files with some examples of the type of base plate you are trying to make.
If you are using inventor I can send you a step file, but that doesn't provide any insight into the design process.
Edit: Should Have Seen this was posted in the inventor section. My bad.
Unread 03-27-2013, 05:40 PM
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Rookie Year: 2010
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
A lot of programs allow you to create features using rules. What I have done in the past is define a series of points where I want the lightening features and then have the computer follow the rule that places those extrusions at those points. It takes for ever to set up, but you only really have to do it once.
Depending on the program you use, the names for this might be different. For inventor it is all done under I-Properties.
Here is a dull demo for inventor 2011
http://www.youtube.com/watch?v=HiJGymwstpE
Proper instruction videos are also available on youtube.
Good luck
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 03-27-2013, 05:43 PM
Rookie Year: 2010
I tried doing that, but how do you get it so it perfectly fits the width and height of the plate. It always ends up that they do not line up correctly in the end.
Unread 03-27-2013, 05:45 PM
bearbot's Avatar
bearbot bearbot is offline
FRC #2849 (ursa major)
bearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nicebearbot is just really nice
I have been using inventor for a while and have done some diamond plated baseboard.I first create the diamond sketch on the plane then choose what type of an array I want.Then generally use rectangular array and select the dimension and how many i want in each row and column.Then I extrude them and the filet the tops
FRC Events:
Chesapeake Regional Rookie inspiration award 2009
Offseason Event:
Battle O'BAltimore Champions 2010
FRC Teams :
2849 Ursa Major (Student 2009-2011) (Mentor2011- Current)
5979 (Mentor 2015-Current)
Unread 03-27-2013, 06:12 PM
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
1. Draw center lines for the center of all of your ribs, and tweak the geometry as needed to make sure all of the ribs look good.
2. Convert all center lines to construction sketches.
3. Select all of these construction lines and use the offset line tool to offset them.
4. Use the power trim tool to remove all unnecessary line segments.
5. Extrude cut the holes.
6. Use feature fillets to add fillets to all of the corners. I almost never use sketch fillets, as they can be difficult to remove / edit later on.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 03-28-2013, 12:39 AM
Twins Inc.'s Avatar
Twins Inc. Twins Inc. is offline
wait....are you a twin??
AKA: Zach Larson
FRC #2605 (Sehome Seamonsters)
Team Role: Leadership
Rookie Year: 2011
Twins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really niceTwins Inc. is just really nice
Just to add another method (that I think will work) you can also make the appropriate ranges using linear pattern in sketch, and then extrude the triangles. In the Extrude menu check "Draft Inward" and make the degree very steep, to get the diamond plate effect. I also think that you can extrude all of your diamonds in one extrude command, and thus later change the drafting angle and the overall look of the diamonds pretty easily.
Hope that helps!!
Unread 03-28-2013, 12:56 AM
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
It took me about 6 tries over 4 hours to get it right. Don't think that those of who are coming up with this sort of work are insanely skilled or have some magical way of doing this quickly. It really takes a lot of time.
Unread 03-28-2013, 01:04 AM
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Rookie Year: 2000
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
It took me about that long just to fillet all the corners. There were like 300. I'm not sure that was worth the effort.
Unread 03-28-2013, 01:12 AM
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Did you use filletexpert?
Also, you can fillet before the pattern.
Unread 03-28-2013, 01:13 AM
Team Role: Teacher
Yeah, I'm with you on that one. My CAM software would have just done toolpaths that would have given me a fillet radius of the tool radius, but I don't want the tool to squeak in the corners when milling, so I put in all the fillets. I could pattern many of them, but after adding all the electronics mounting locations, there were many that had to be manually put in. It takes a decent computer. And for all you who waterjet your diamond pattern baseplates, yeah, we did ours on a router. 6 hours of babysitting a machine with a spray bottle of WD-40 in-hand. In the end though, I'd say it was worth it. If done well, it's a really nice piece, and makes it a joy to weld and wire.
Unread 03-28-2013, 01:15 AM
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
I figured out a way in Solidworks that reduces it from a tedious process to a single feature and 2 mirrors (really speeds it up because it eliminates the patterns and associated lag). To do this I draw out the belly pan in 3 steps. Step 1 uses extrude thin, step 2 and 3 use mirrors about the front and right planes.
If I were to do this in Inventor I would do a similar process but instead of using extrude thin (drawing just lines) I would actually draw out the first shape.
In all this process takes the hours long drawing and turns it into about 10-20 minutes. At least for me this has almost no lag, this is likely because the process reduces the number of relations (what slows the model down when patterning).
ID:	14462  Click image for larger version
ID:	14463  Click image for larger version
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
My poor old little laptop dies when I try those patterns -__- I need a new laptop. I end up suppressing them while working on stuff anyway.
  #15   Spotlight this post!
Unread 03-28-2013, 01:22 AM
Gray Adams's Avatar
Rookie Year: 2000
It was more because of all the extra mounting geometry we added in.
I was using Inventor at the time, and if an equivalent Filletexpert exists, I didn't use it. I still haven't learned how to use it, but now I might look into it.
Yeah, we didn't want the sharp corners from the laser or the extra time it takes when the machine doesn't smoothly run through the corner. The time and machine wear considerations weren't really for us so much as they were for our sponsor.
But hey, at least you have a nice big router. I can think of at least a few (hundred) uses for that.
