Thread Tools |
Rating:
Display Modes |
Re: VEXPro - After the season
Electric Solenoid Actuators are legal for use in FRC since last season. See R32 for the specs and R70 for the maximum output of your Solenoid Breakout (alternatively, you can use relays). I speculate that the primary reason for this rule change was to facilitate shifting without pneumatics. I expected to see some teams use them or Andy Mark/VexPro to make a electric solenoid shifter kit. However, I haven't seen anything yet, maybe it is something they will develop this off-season (I dont know what the market is like for non-pneumatic shifters and the ball shifters are new this year). There are many design considerations for electric solenoids including: -Push vs. pull (this determines your default gear ratio) -Return spring (to keep you in default) -Solenoid package and mounting bracket -Force vs. stroke (it varies, look for it in specs) enough to shift -Wattage It would be nice if one of the vendors engineered a nice solution for everyone to use. Last edited by The Lucas : 31-03-2013 at 15:01. |
All,
The VEXpro wheel hubs (including Mecanum Wheels) are all made from glass filled Nylon. One of the many reasons we used glass filled Nylon was so that thread locker (specifically, Loctite 242 or equivalent) can be used. We will make it more clear in our documentation, but in all cases when using steel screws with aluminum or steel mating parts, thread locker should be used. There is nothing in the standoffs inside the wheels to physically lock the screws. I highly recommend using thread locker with all of our hex standoffs in all of the VEXpro wheels. Paul |
Versaplanteries are amazing and pretty much allow our robot to exist.
We're also using a full VEXpro drive train with the chassis in a day, single speed gearboxes (5.33:1), vex sprockets, and versawheels. I will say that we have seen heavy ware on on our versawheels. The four that are on the ground all the time are practically round after our two regionals. They are first on our list of things to change out at Razorback next week. I still love them but we have worn them down enough to need replacement. At $5 a wheel I really wouldn't care if I had to change them each regional. Also I can't say enough about how awesome their hex shafts and 1/2" shaft stock are for the price. Plus their hex shaft collars are awesome as well. |
We went with single speed, 2 stage transmissions, and they have worked great on our competition robot as well as our practice bot. The only comments I have about Vexpro are:
The plastic transmission housings when we got them early in the season did not give good gear interface and were noisy. We immediately decided to make our own plates and spacers, and they have worked great. Nice and smooth, and no discernible wear on the gears. The lack of sufficient inventory on the hex bore Versahubs (217-2592), which are still listed out of stock. Modified AndyMark hexhubs to our Vexpro wheels. The few we did get were great. Fit on the hex shafts though some were too tight. Used a Jewelers file and dressed the flats to get a good sliding fit. Next year we will machine the shafts to .500 d. and key to 1/8 as in the past for better concentricity. Initial shortage of hex bearings created a lot of anxiety as well. Longer shafts on the ball shifters for wider wheels on WCD would also give more design versatility. We used an additional hex bearing in our frame on the shaft of the single speed tranny to take some of the load off the shaft bearings in the housing. Couldn't do that on the ball shifter due to the shorter shaft. ![]() Last edited by Teched3 : 06-04-2013 at 14:01. Reason: grammer |
The piston was probably loose all day before we noticed it. The Ball Shifters worked well even with one of the pistons hanging on by a few threads. ![]() |
After the Bit Buckets' robot lost an output shaft in their last qualifying match, we made a quick crutch to try to prevent it happening in eliminations. This is the Rube Goldberg fix....good for entertainment value, maybe not the best solution to the problem, but they were still driving fine when they lost.
Some more comments on VEXPro after this weekend:
Versaplanetaries-they held up completely fine for us(except for a busted 775-nothing VEX related) except at one point, the CIM output shaft flat out broke. Now, this could just be due to considerable wear of the shaft throughout the season, but we were lucky to have it happen to us at the end of the day with no matches left in that day. Ball Shifters-Worked great as they did before, except for one match where the mounting screws of the pancake cylinder became loose, which was a relatively difficult repair. Also we experienced another issue that another team also experienced (from losing their pneumatic system for a match)-when the cylinders lose air, it seems that they default to neutral gear-it'd be nice if it were a spring return/release cylinder that defaulted to either high or low gear. |
