Go to Post FIRST is not about lowering the bar to those with the smallest expectations, but helping helping all teams exceed the standards set by the best. - Allison K [more]
Unread 31-03-2013, 23:53
shhrz shhrz is offline
FRC #2630 (Thunderbolts)
Rookie Year: 2011
shhrz will become famous soon enoughshhrz will become famous soon enough
Re: Who is going to be on Einstein?
Originally Posted by dodar View Post
1. Corner-to-Pyramid
2. FCS
3. Ground Pickup
You will not win this year unless you go full offense.
I tend to agree with this, however adding to it:
2. FCS that is PRECISE (meaning 85%+) with the ability to go to pyramid if blocked. This allows him to "pin-down" a deefnding robot, who will try to block him, and so he can move to pyramid.
All robots should have AT LEAST 10 climb points, and at least one of them should have mrore than a 3-disc auto. Regardless, for all of them - auto should be perfect...
Unread 01-04-2013, 00:11
c.aldridge's Avatar
c.aldridge c.aldridge is offline
FRC #2158 (ausTIN Cans)
Team Role: Mechanical
Rookie Year: 2010
c.aldridge is an unknown quantity at this point
2. FCS
3. Ground Pickup
I don't necessarily agree with that. The number 1 alliance at Alamo did not advance to finals with their full offensive team. They were composed of:
1. 1477 with a guaranteed 3 frisbee auto and tried to get the middle 4
2. 624 with a 5-7 frisbee auto
3. 457 with a 3 frisbee auto
They started the semis with 70+ pts and still lost against a quick shooter from 4063, 2789 playing defense and allowing 2468 to shoot full court. It was close, but the primarily offensive team was upset.
Also just realized you were at Alamo so you were able to see this occur.
2012 Alamo Regional Chairman's Award Winner
Unread 01-04-2013, 00:14
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
Rookie Year: 2007
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
The #1 at Alamo wasnt full offense and you cannot honestly compare Alamo to Einstein and Champs. Imagine giving 1986/1806 or 2056/1114 a capable ground pickup or FCS. Seeing as we saw the 1114/2056/FCS at GTRE, they threw up like 230. And that was just a FCS that sprayed and prayed and played pretty much to just feed 2056.
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 01-04-2013, 00:21
c.aldridge's Avatar
Rookie Year: 2010
I would say they were fully offensive because 457 ended up shooting at times and did not play absolute defense. I also understand Alamo was not on the level of Einstein, just that the fully offensive team will potentially fail. Slowing down the other team in this game, unless they are nimble and fit under the pyramid, can be very easy if you allow yourself the opportunity. I see it from last year, although game object deprivation cannot be accomplished this year, slowing down the other team by playing defense took 16's alliance to the top.
Unread 01-04-2013, 00:38
StAxis's Avatar
StAxis StAxis is offline
Mentor/Drive Coach
AKA: Zach CH
FRC #1902 (Exploding Bacon)
Rookie Year: 2011
StAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud ofStAxis has much to be proud of
I think that the ideal alliance would have very close to the setup we had with our winning alliance at South Florida (180-1902-1251)
1. Full court shooter capable of pyramid shooting in case of a "SPAM Filter" (84 inch blocker named after one made by a team trying to stop 180's shooter)
2. Cycling pyramid shooter
3. Defense and Floor pickup
Essentially the full court and pyramid shooter score until they run out of discs (Generally with 55-50 seconds to go) while the third defends, at that point the two offensive robots defend and if one has pickup they go to do that along with the third robot. The other switches to defense.
At least one must have floor pickup capable of 7 disc autonomous.
Preferably one offensive bot has a 50 point climb.
The winning alliance will have to be a very versatile alliance capable of playing 3 robot offense or full defense in order to counter the strategies of whatever team they play against.
In order to win matches you do not have to score your maximum number of points, you just have to make the score difference a maximum, which is the reason the 180-25-16 alliance did so well. They prevented their opponents from scoring quickly and maximized their ability to score quickly that is the one thing that will always remain true no matter what game.
Unread 01-04-2013, 00:32
ErvinI ErvinI is offline
AKA: Ervin Ibadula
FRC #0865 (Warp7)
Rookie Year: 2011
ErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really nice
Waterloo, not GTRE .
I personally don't agree with a full out offensive team, especially when one of those robots is a FCS. When you are limited to 45 discs + floor pick-up your alliance will starve itself before the end of the match due to your FCS' ability to unload every few seconds. Instead, an "enforcer" could be used to protect the FCS from any blockers. After all, the maximum height of a FCS will always be shorter than the maximum height of a defender. Once the FCS has don't its job, the defender has the time to do its climb, preferably a climb-and-dump or just a 30.
Therefore, an alliance that could easily make Einstein is:
1. A tall full-court shooter that is relatively accurate.
2. A floor pick-up robot that can clean up any misses and shoot 7 discs in autonomous.
3. A quick climber with a drivetrain strong enough to hold up against robots trying to go through it. Preferably with dumping capabilities.
Unread 01-04-2013, 06:32
MooreteP's Avatar
MooreteP MooreteP is offline
Zen Archer
AKA: Senor Mas
FRC #0571 (Team Paragon)
Rookie Year: 1998
MooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond reputeMooreteP has a reputation beyond repute
I concur that these are the types of alliances that will show up out of half of the divisions.
It may come down to a bad cRio, a disconnected battery, or (hopefully not) the FMS.
Unread 01-04-2013, 00:33
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
There also wasn't very much defense being played at GTRE.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 01-04-2013, 02:48
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
Rookie Year: 2011
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
Awfully glad we went with a floor pick up seems to be turning out to be a very desirable attribute. After playing a match with 1662 (feeder station pick up) and scoring 131 disc points collectively with them I absolutely agree that having a feeder station/ground pick up alliance combination is a force to be reckoned with, not to mention 987 and 254 who with 2 ground pickups broke the 200 point mark several matches in a row. It seems that those strategies complement each other better than almost any other. A full court shooter has the potential to either destroy the competition or get shut down very easily without an assisting counter-defense teammate. Whether they get blocked our not will decide their matches. I also think that having two 30 point climbers on an alliance also gives a bigger advantage than people have been saying as it is at least 60 more almost-unblockable points every single match without including the potential for an additional 20 point dump. If the other alliance is all 10 point climbers they have to be leading by 60 points at the buzzer just to match the other teams score. Aside from offense I've seen some defensive teams such as 294 at CVR completely shut down the opposing offense. However, the defensive role this year can be filled very easily by any fast robot with a good driver; meaning that we will probably be seeing a couple of alliances made of 3 offensive powerhouses that have the versatility to play any role during the match.
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
Unread 01-04-2013, 06:12
bardd's Avatar
bardd bardd is offline
That loud guy
AKA: Bar Danino
FRC #2212 (The Spikes)
Rookie Year: 2011
bardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant futurebardd has a brilliant future
I don't think any estimation we make can hold before division lists are published. You have to look at every division independantly and only then you can try and guess which robots and which types of robots can qualify.
For example, if you get a division with lots of canadians defenders have a good chance, since canadians are mostly offensive and not very good around defence (according to what I saw at waterloo and GTRW).
Team FRC#2212 The Spikes, 2011-...
Builld leader 2013
Drive coach 2012-2013
Mentor 2015-...
Unread 01-04-2013, 12:30
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
I want a return of the "EH Team"
That is all.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 01-04-2013, 12:32
dodar's Avatar
Rookie Year: 2007
That is all.
2056 - Ground Pickup
1114 - Corner-to-Pyramid
4334 - FCS
...omg...it's like they planned this out...
Unread 01-04-2013, 13:09
bardd's Avatar
That loud guy
AKA: Bar Danino
Rookie Year: 2011
That is all.
To be honest, I would very much prefer it if those 3 all ended up at different divisions (if 1114 and 4334 end up together, it's fine, but no other combination).
While I loved watching them play and loved 1114 and 2056 together at their regionals this year, I think those teams together make the game un-even, even for some of the bigger powerhouses (maybe all of them, they definitely risk all the teams I saw playing), and to be honest, it's getting kind of boring. I'd rather see them pair up with other big teams, and maybe face off at Einstein.
Builld leader 2013
Mentor 2015-...
Unread 28-04-2013, 15:01
registered lurker
AKA: Jake McCann
FRC #3501
Rookie Year: 2011
That is all.
This nearly happened in Curie, if we hadn't scorched the field 2056 may have ended up with 1310, and if 4814 had lost their last qual match they could have been the third robot on that alliance, that would have been an incredible alliance.
2011-2015: 1678
2016: 846
  #15   Spotlight this post!
Unread 02-04-2013, 11:39
David8696's Avatar
David8696 David8696 is offline
I.A.A.R. Lord
AKA: David Bluhm
FRC #2485 (W.A.R.Lords)
Rookie Year: 2012
David8696 has much to be proud ofDavid8696 has much to be proud ofDavid8696 has much to be proud ofDavid8696 has much to be proud ofDavid8696 has much to be proud ofDavid8696 has much to be proud ofDavid8696 has much to be proud ofDavid8696 has much to be proud ofDavid8696 has much to be proud ofDavid8696 has much to be proud of
Could someone tell me exactly what Einstein is?
