Go to Post Now, FIRST has taken over my life (and my harddrive)! - Kate00 [more]
  #16   Spotlight this post!
Unread 01-04-2013, 19:55
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Re: Battery failures?
Originally Posted by Woolly View Post
Team 1806 has done so for years now.
Our original handles were 2 zip ties that wrapped around the casing that linked together a cable covered in plastic tubing.
This year our battery handles are a strong blue woven material attached to the battery top by a mounting plate that bends into the normal handhold for the battery. The mounting plate also contains battery identification information, as well as a QR code that links to the material information and proper disposal information for the battery.
I was going to use S.W.A.T. as an example, but Woolly beat me to it. I will say that their system is really nice; it's simple & sturdy. I will also say that when I inspected them at GKC I had to look twice at the battery; if you only glance at them it looks like they've drilled into the case.
Mentor http://www.teamtitanium.org/
  #17   Spotlight this post!
Unread 02-04-2013, 02:02
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Rookie Year: 2007
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
Originally Posted by fb39ca4 View Post
1983 has fabric pouches for each battery with a handle.
I believe we've been doing this for four years now. They are really handy and I like how they look
I'll edit this post and add a picture to it tomorrow night.
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
  #18   Spotlight this post!
Unread 02-04-2013, 12:48
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
Rookie Year: 2010
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
We have had two, new 2013-purchased MK batteries fail this year. Both times the batteries leaked acid from the vent area, and both times were in practice at our field.
This year we have our battery lying down under the robot, with a plug-type piece keeping it captive in place, holding it on the top. We think that the leaks occurred due to it being a tight fit, and taking a few hard hits during practice against other robots. This may have put enough pressure on the seals to break them enough to allow a small leak. We have since replaced the plug with one that is shorter and added more foam to each end to help absorb impact. Since then we have not had another failure.
Thankfully both times, the leak was small, found quickly, and any spill was cleaned up fast. Just in a very inconvenient location.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
  #19   Spotlight this post!
Unread 02-04-2013, 13:41
coalhot's Avatar
coalhot coalhot is offline
Assistant to the regional manager
AKA: Phil
FRC #4454 (Artisan Rockets)
Rookie Year: 2007
coalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant future
Send a message via AIM to coalhot
We haven't had any batteries fail this year. Usually though, they can fail due to multitudes of different reasons. Carrying the battery via the cable, dropping, or accidental shortage (my personal method of killing a battery one year).
Using the battery beak is one way to prevent issues. Usually a battery that is going to die shows signs ahead of time. But nothing trumps good battery safety and care.
Also, we've been using a pair of the triple bank battery chargers for two years now. Only issue is that someone blew out one of the banks, so we have 5 batteries charging instead of 6.
Current home, 4454 (Glowa's ghetto Philly FRC team). Check us out!
My posts represent my personal views only, and do not represent the views of my team, its school, sponsors, or FIRST.
  #20   Spotlight this post!
Unread 02-04-2013, 14:06
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
We have had 4 fail within the last year. 1 at champs last year overnight began leaking. We quickly got it contained and cleaned up the next morning when we found it.
During build season we were trying to fit a battery into the practice robot for locating the battery mount and it wouldn't fit, discovered that the battery had started to swell.
After that I bought a battery beak and we have been checking our batteries and pulling the ones that test fair out of service. We plan to use this to periodically check the batteries and track the data.
At QCR last weekend we lost 2 batteries that tested good but then immediately dropped voltage and now test bad. They were both older batteries, maybe 2010 competition season.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
  #21   Spotlight this post!
Unread 03-04-2013, 19:52
Rookie Year: 2007
It turns out we are using the stock Andymark Pouches:
http://www.andymark.com/product-p/am-0620.htm
Founding Member
  #22   Spotlight this post!
Unread 04-04-2013, 08:40
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Thanks for all of the replies guys.
Al/Ether - A second inspection of the robot shows a spot where there is a remote chance that the battery lead could be pushed pretty hard by a mechanism. I think this could have caused one of the leads to fracture. This will be cured with better wire control.
Steve - Our robot also has the battery mounted low and without much padding, plus we played a good bit of defense. This seems a likely cause for the leakage failure. We'll look into padding options.
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
  #23   Spotlight this post!
Unread 04-04-2013, 13:34
Rob3653's Avatar
Rob3653 Rob3653 is offline
Alumni
FRC #3653 (Botcats)
Rookie Year: 2012
Rob3653 is an unknown quantity at this point
We had a brand new battery fail at us at South Florida. Apparently one of the leads of a port on the 3 port battery charger had its polarity switched in manufacturing. The battery would show 3-6 Volts after we noticed it had died.
Teams need to check, and re-check the batteries and chargers before they put them to use!
  #24   Spotlight this post!
Unread 05-04-2013, 00:08
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
Rookie Year: 2012
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
We had a battery from 2011 which died this year. Cause of death was most likely being left discharged over the summer.
Showed ~10.5 volts which collapsed to nothing under any load, the Shumaucher charger would remain in desulfation mode indefinitely, and after 12 hours on the charger it would read ~11.5 volts, but then drop .1 volts every 30 seconds until it stabilized around 10.5 volts again.
Keep the batteries charged to at least 12-12.3 volts at all times. If you just leave them in storage like we did, check them every month with a multimeter and make sure they're in a healthy range.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
