Go to Post Are you saying you want to submerge your circuit board in an open container of liquid nitrogen? - Ether [more]
Unread 01-04-2013, 23:17
bs7280 bs7280 is offline
FRC #3734
Team Role: Leadership
Rookie Year: 2011
bs7280 has a spectacular aura aboutbs7280 has a spectacular aura aboutbs7280 has a spectacular aura about
Supershifters and Mechanum wheels
the team I was on had some trouble with driving this year (it wasn't great but it did the job). Having mecanum wheels would have helped greatly in lining up our robot to grab/shoot frisbees and we also had some trouble with speed and getting blocked.
How well does a set of four mecanum wheels deal against being blocked? and how fast could a set of mecanum wheels get a robot up to compared to standard wheels?
Are supershifters worth it? and how would a supershifter on each mecanum wheel do (assuming the money didn't matter)?
thanks! -3734
Unread 01-04-2013, 23:23
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Re: Supershifters and Mechanum wheels
What were the details of your team's drive train this year? Also, what are the details of where you had trouble lining up? If you had trouble lining up with the feeder station slots, it could be that having a wider target for your human players to feed the discs into would be the solution rather than altering your drive system, for example.
[2016-present] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 01-04-2013, 23:25
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder
AKA: noops
FRC #1648 (G3 Robotics)
Team Role: Team Spirit / Cheering
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Before you pursue an entirely new drivetrain, let's break down your current one. What setup were you using? (Gearboxes, number of wheels, which wheels, wide configuration or long configuration, etc). Could you also provide us some video of the robot driving? There's more you need to look at before making a decision such as moving towards an omnidirectional drivetrain. The kit drivetrain is one of the easiest and most powerful drivetrains out there.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
RIT Graduate Student, CompE
Unread 01-04-2013, 23:52
FRC #3734
Rookie Year: 2011
Please keep into consideration that our season is over (we had a good run, first time getting picked) and we are currently working on a new frame from scratch (preserving this years bot) in order to test drive trains. We also have a good amount of money left in this years budget that we can most likely buy the gear boxes (we already had the wheels) especially considering that they are reusable.
This years drivetrain was a 6 wheel tank drive on the andy park standard KOP frame using the long formation with omni wheels in the front and back of the bot, and kit standard wheels from andymark (highgrip) in the middle, all 6 inch. we had 4 cim motors on two cimple boxes. We added the omni wheels because it could not turn for its life on carpet. It worked well in competition, as it could run very well when it was just going back and forth collecting and shooting frisbees. I was pleased with it because last year we were basically a sitting duck with our 6 highgrip wheels powered by 2 cims.
The problems came up when we had two line up our bot to shoot/load frisbees. Unfortunately our bot could not change the firing angle at all, and had no sensor, so the shooting had to be lined up by shooting very specifically at the bottom of the pyramid. It worked great in auto mode, but telop was tricky because with tank drive it was impossible to make slight adjustments to alignment. Especially with lateral movement.
The feeding was the same thing, but easier because we could communicate, still took way too long. I will admit our feeder could have been much better designed. On the optimistic side, lining up on the pyramid was easy and took no moving parts at all for climbing.
I don't have any great videos, but we have some O.K. ones on our website with more elsewhere that need to be uploaded. there really are not any obvious problems at first glance, but it is defiantly not fast, and it does not block/handle blocking well.
Unread 01-04-2013, 23:58
ablatner ablatner is offline
AKA: Andrew Blatner
FRC #0100 (The Wildhats)
ablatner is on a distinguished road
Shifters are great, but I'd have to recommend against Mecanum wheels for the usual reasons. You can find many threads on the subject. Many of the top teams use 6 or 8 performance wheels. I know 254 almost always uses the same drive train with eight 4" wheels (this year maybe six because of reduced size). Many other teams have the same setup too, unless they have a good swerve drive like 1717 last year.
Unread 02-04-2013, 00:03
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
FTC, I have returned.
AKA: @doctorfogarty @GarnetSq
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
We used 4 AM SuperShifters on our Mecanum prototype base, but we decided it wasn't something we'd ever use in competition unless another game like LogoMotion came about.
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 02-04-2013, 06:01
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
254 almost always uses 6wd, not 8wd because you have a lot less parts to make. They also usually vary their wheel size based on the game, but usually stay very small. If I remember correctly in the past few years they've been using wheels that range from 3.5" - 4.5" in diameter.
The kitbot on steroids is a very good drivetrain. It's very easy to make and will give you a drive that is better than 90% of teams. Having a reliable, easy to make drivetrain will give you more time to build a reliable manipulator, tune your programming, and get drive practice.
I find that omnidirectional movement is usually overrated. Mecanum and holonomic drives tend to have a lot of problems, especially when you want to try to get around or play defense. Swerve drives take up a lot of resources. First of all, they are complex, hard to design right, and take a lot of time to machine. Also, code is very complex, and if you don't do your code right you will be a sitting duck.
One of my favorite examples of the complexities of doing swerve right is 973's 2012 robot, Encore. 973, being a powerhouse and the 2011 World Champions, they had the resources to build a very good independent swerve drive. However this took up a lot of their resources, and ended up detracting from the other parts of the robot. This year, 973 decided to revert back to a west coast drive. In my opinion, this decision benefitted them tremendously. With more time and resources to divert to their manipulator, 973 was able to spend more time tuning and practicing with their robot. I feel 973 had by far the best robot at the LA regional, leading them to their 2nd regional win.
That said, I think you should work with building the kitbot on steroids during the offseason. With so many good new products from many new vendors, you may eventually want to spend time improving the kitbot on steroids(i.e. add shifters) and even creating your own custom drive. However the kitbot on steroids will put you on the right path.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 02-04-2013, 10:16
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
I dont get it. If you used the kitbot chassis then you have the same chassis we did. Long orientation, 6 kitbot traction wheels, 4 CIM's on toughbox minis as provided in the KOP. Perhaps you didnt notice that the middle hole on the chassis material is off center and you assembled it with the middle axle up? We used, for the first time the entire kitbot chassis and it was strong, reasonably fast and turned on a dime. We seeded 11 in both Wisconsin and Buckeye and made it to finals in Buckeye after being first pick by the first seed. This was, with the belt drive, the MOST BULLETPROOF chassis we have ever used. I am never going back to chains and using onmi's on the ends is just wasting traction.
We had no trouble pushing people around most of the time and having 6 traction wheels made it almost impossible to push us around. The only thing I would change in the future would be to go back to super shifters to give us more speed and power when needed.
Check out you chassis assembly, I bet you have the center axle raised instead of lowered.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 02-04-2013, 10:20
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
FrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond reputeFrankJ has a reputation beyond repute
Since mechanum needs four gear boxes, shifters add bit of weight & complexity. you would want to gear them fast & faster since you are not going to win pushing matches against well built pushers anyway. I don't think shifters would be worth it. They really don't do as bad as most think against the average drive train. Once again I am not talking about winning pushing matches as much as avoiding them. A well driven mechanum with good drivers & a plan can drive around pushing matches. In this game, lining up on the feeder & aiming is a big plus for mechanum.
Unread 02-04-2013, 11:16
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Originally Posted by FrankJ View Post
Since mechanum needs...
A well driven mechanum...
...big plus for mechanum.
Hey Frank, did you do that on purpose ? :-)
Unread 02-04-2013, 13:49
FRC #3734
Rookie Year: 2011
Since mecanum needs four gear boxes, shifters add bit of weight & complexity. you would want to gear them fast & faster since you are not going to win pushing matches against well built pushers anyway. I don't think shifters would be worth it. They really don't do as bad as most think against the average drive train. Once again I am not talking about winning pushing matches as much as avoiding them. A well driven mecanum with good drivers & a plan can drive around pushing matches. In this game, lining up on the feeder & aiming is a big plus for mecanum.
Thank you for your advice! this answered a lot of questions/concerns that I was having. We are most likely not going to go the shifter/mecanum route in the future as it is expensive,heavy, and not worth it. The reason that I was concerned about being fast and able to deal with pushers was that in our elim rounds we had to defend our teams long range shooter from some of the robots with blockers.
When would you say mecanum is worth it?
Unread 03-04-2013, 21:03
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
I would say that mecanum is worth it if and only if:
1) The game requires an extremely high degree of maneuverability.
2) The game does not require the movement of heavy objects, or allows for said heavy objects to be carried in the middle of the robot (not other robots).
3) The team has a good programmer.
4) The team does not have the resources (pick any or all of time, personnel, offseason, money) to pursue swerve, or wants to use a KOP-type frame.
Otherwise, swerve adds extra push to the maneuverability.
Oh, and:
5) The team has already prototyped the system, at some point.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 03-04-2013, 21:18
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
We now have 7 regional wins on mecanum wheels so count me in the "likes them" column.
Unread 03-04-2013, 21:36
J_Miles's Avatar
J_Miles J_Miles is offline
FiM Referee
AKA: Jared Miles
no team (EngiNERDs)
J_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to beholdJ_Miles is a splendid one to behold
Perhaps I'm simply biased, but as a driver I loved driving a robot with mecanum wheels. Our 2011 robot was built on a mecanum drive and won the 2011 Ann Arbor District competition, the 2011 Troy district competition, as well as two local off-season competitions in Michigan. It was definitely a machine to be reckoned with in spite of what many would consider to be a poor choice of drive train.
With that said, there are a few advantages to mecanum drives, but I think they're quite context-based. 2011 seemed to be an excellent year (if there is such a thing) to use the system because of: A) The totally flat field, B) Sizable protected scoring zones C) A shallow protected zone (making the ability to strafe quite useful). For this reason an omnidirectional drivetrain seemed the way to go, but we chose a mecanum drive for its relative simplicity and our previous experience with it, and our year was spectacular because we were able to put lots of effort into our end-effector and other mechanisms besides the drive, and to build a solid mecanum drive there isn't a lot of fancy programming necessary besides speed control.
Mecanums have the advantage of being able to immediately change from forward & backward motion to sideways motion without having to worry about the wheels turning. Driving on mecanums also means that shifting transmissions are sort of irrelevant (as you aren't going to get much pushing power from mecanums and, as such, shouldn't need a significant boost in torque), and because the rollers allow for low-resistance turning.
Surely there are sacrifices made when designing a mecanum drive for a robot, but I still argue that they are a solid option if you want a simple omnidirectional drivetrain and are willing to live with the consequences.
Also, as an aside, the "drunk drive" (as we called it) that comes with mecanums significantly changes the driving experience, and I personally found it a lot more fun than driving the standard tank drive we used in 2012.
  #15   Spotlight this post!
Unread 03-04-2013, 21:55
Ether's Avatar
Rookie Year: 1969
What was your driver interface? e.g. something this this:
forward/reverse Joystick1 Y axis
strafe left/right Joystick1 X axis
rotate CW/CCW Joystick2 X axis
... or something else?
