Go to Post The only basis on which a team should be awarded the chairmans award is the content of the submission, not the way in which it is presented. - KenWittlief [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 03-04-2013, 12:36
smcmahon's Avatar
smcmahon smcmahon is offline
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Team Role: Coach
smcmahon is an unknown quantity at this point
Question [FTC]: Using Autodesk Inventor for FTC models
Good day,
At our school we have a license with Autodesk and get new software each year. We currently have Autodesk Inventor Professional 2013 - Educational Institution version.
We are trying to get some 3D models going of our latest FTC robot. We stopped by PTC's website and downloaded their 3D kit of parts. The files are made for Creo I guess, and are .PRT and .ASM files
When we try to open them with Inventor, we get an error and it will not continue. The error is as follows:
"Unable to convert Pro/ENGINEER or Creo Parametric file to Inventor file."
I also attached a screenshot of this error.
Does anyone know what's wrong, and/or why we cannot open these files?
Or perhaps where to get the FTC parts pre-modeled in a more neutral format, like .STP?
FRC 2656 | FTC 5526 | VEX 9656
Unread 03-04-2013, 16:56
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Re: [FTC]: Using Autodesk Inventor for FTC models
I ran into the same issue trying to bring those parts into Solidworks
Maybe there's some sort of converter software needed?
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 04-04-2013, 02:52
399thegeneral's Avatar
399thegeneral 399thegeneral is offline
Mentor
AKA: Jackie
FRC #0973 (The Greybots)
399thegeneral will become famous soon enough
You can find a lot of FTC parts here if you poke around a bit here. You can configure it to download Inventor part files but I haven't had the best experience doing that so I just usually grab the STP file.
www.greybots.com
Unread 04-04-2013, 10:24
smcmahon's Avatar
The Architect
AKA: Sean McMahon
FRC #2656 (QUASICS)
Team Role: Coach
Funny, I was just over at 3D Content Central before I came back to check on this. Searching "FTC" there will get you a decent amount of stuff, as will "tetrix" as you suggested. Good stuff, thank you!
Unread 04-04-2013, 14:32
CENTURION's Avatar
Watch out for some of those though, I ran across some Tetrix rail pieces that had an incorrect hole pattern. You may want to check that they are correct before using them for critical design.
Unread 06-04-2013, 03:59
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Rookie Year: 2007
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
I have an outdated library formated for 2012, you simply import the parts and save them to 2013 whenever you save.
http://ge.tt/5hscqpb/v/0
Give that a go.
- Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
