Re: SMC Solenoid Manifold Deem NOT LEGAL at SVR
I am sorry you had some problem with this part. I have received a call or two on the legality of this part over the season. At Champs they will be considered legal.
I should mention that I was inspecting at SVR, but wasn't the LRI or the inspector described above (though I did notice and speak to someone from 766 about this issue prior to their initial inspection).
The fundamental test of legality depends on the working pressure rating of the pneumatic device. The rule isn't clear on the distinction between manifold and valve, but the manufacturer's documentation (not attached, because I don't know which version is most authoritative) implies that manifolds are included in the rating by picturing them alongside the table of specifications, with valves installed. The relevant rules are R76 and R78: Quote:
The inspector was right to inform you of the violation, based upon the printed rating on the SMC SY-series valve you were using (0.7 MPa = 102 lb/in2). (The Festo VUVG-series valves used by other teams were rated at 8 bar = 116 lb/in2.) The burden of proof is upon the team to justify a higher rating, based on documentation. Appeal to the LRI is also allowed, and in this case, extenuating circumstances caused the LRI to rule that you (and everyone else) could use the valves. In discussing this with the LRI, mitigating factors included the fact that FIRST had permitted these valves in the past, that the documentation was not clear on the definition of the pressure ratings contained therein (were they the limits of function, or the onset of failure?), that they were available as FIRST Choice parts (or via PDVs in the KOP, which isn't exactly the same thing), and that there was no credible safety hazard. After the LRI made his ruling, I documented 30 robots (of 59 at the event) that had valves bearing pressure ratings less than 125 lb/in2—almost all were the SMC or Festo valves mentioned above. I did not verify which robots were carrying the requisite relief valve, but didn't see any additional relief valves on the robots I inspected in detail. Spare parts had only one relief valve to give, and that was best retained in case someone needed to protect their 120 lb/in2 system. We were also in contact with IFI, who verified that they had conducted their own tests and were willing to warrant that the valves would be safe up to 0.9 MPa = 131 lb/in2 with a safety factor of 2.0. SMC also gave IFI a vague assurance about the working pressure rating, but because of several inconsistencies in SMC's product naming scheme and their published documentation (according to IFI, who heard this from SMC, the newer SYJ-series valves are printed with model numbers in the SY-series—so there are two distinct but very similar product lines with the same SY-series model numbers), it's not possible to conclusively establish the valves' performance limits from the datasheets that a team could present at inspection. Given the rules, and the other aspects of this situation, in my (unofficial) opinion, this should be viewed as special permission to operate without the mandatory safety device, rather than a declaration that these valves are legal on their own (alternatively, they can be legal with the relief valve). I'm comfortable with that from a safety perspective, because these valves are operated at a nominal system pressure of 60 lb/in2 or less, and even if overpressurized (e.g. by mechanical compression of an actuator), they will fail in very boring ways. Note also that the rules only refer to a manufacturer's rating (as opposed to a vendor's)—this isn't fair to IFI, because their documentation and efforts to test the valves are not officially recognized by FIRST. I'd therefore consider the use of vendor's data to be another special dispensation. The most viable long-term solution would involve FIRST improving the pneumatic constraints to tolerate this sort of issue more gracefully. Aside: These valves don't have great information on Cv either—the flow conditions and pressure drop are not indicated. Nevertheless, the SY3xxx series valves have Cv < 0.32, according to the SMC datasheets. |
