Go to Post Last I looked, FIRST wasn't an acronym for inspiration and recognition of robots. It was and is an acronym for inspiration and recognition of science and technology. - JaneYoung [more]
Unread 04-04-2013, 21:41
connor.worley's Avatar
connor.worley connor.worley is offline
FRC #0973 (Greybots)
Rookie Year: 2010
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
NetworkTables issues / custom dash
At the Inland Empire regional, many teams using SmartDasboard encountered code crashes and a flurry of NetworkTables errors in NetConsole. One team using NetworkTables in their code encountered the same errors. I'm looking into writing a custom LV dashboard, but it looks like the legacy Dashboard data functions have been replaced by NetworkTables. Is there any way to avoid NetworkTables besides writing a custom protocol? Thanks.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 04-04-2013, 21:53
Andrew Lobos Andrew Lobos is offline
FRC #0225 (TechFire)
Rookie Year: 2011
Andrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the rough
Re: NetworkTables issues / custom dash
Was there a common programming language the teams with issues were running?
We have had no issues with the Java implementation of NetworkTables communicating with SmartDashboard
I know a lot of NetworkTables has been redone this year, so this may not be relevant, but in 2012 under C++ our robot would crash (not instantly) if we used any SmartDashboard calls. As I remember Netconsole was filled with NetworkTable errors.
Unread 04-04-2013, 21:57
Rookie Year: 2010
Some teams using LabVIEW and C++ encountered the errors when using SmartDashboard. One Java team using NetworkTables directly also encountered the errors.
Team 973 (2016-???)
日本語でOK
Unread 04-04-2013, 22:38
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
The command packet still includes the LV dashboard protocol and it is accessible in LabVIEW
The underlying calls to Netcomm are the same for each language (3 function calls, get common control data, set common control data, set error data) and Netcomm supports it, so you should be able to modify the C++ or Java implementation of the WPIlib to access it. The protocol itself is very simple, it literally just sends two strings across the network. The functions just pack the string.
On the LV dashboard side it's still unbundled just not used.
You can send literal strings through the protocol by itself also, but make sure the strings aren't too big (I think there are around 900 bytes to work with).
We also use this older dashboard data system, and do not run a NetworkTables server at all on our robot (in LabVIEW). We deleted ALL references to NetworkTables (and basically everything else) and started from as low as possible.
Kettering Motorsports
