Go to Post A well-designed shifting transmission, controlled by an experienced driver (or a clever bit of software), is an advantage. - Alan Anderson [more]
Unread 04-04-2013, 21:50
kiushin564 kiushin564 is offline
AKA: Marco Duran
FRC #0564 (Digital Impact)
Rookie Year: 2007
kiushin564 is an unknown quantity at this point
A Different Solenoid Breakout Output Voltage Issue
Hello, my name is Marco from Team 564. We are experiencing an issue where the solenoid on analog channel 5 is working according to the module on the cRIO (corresponding LED is turning on etc.) but, there is no voltage being sent to the valve. If anyone can help it would be greatly appreciated.
Unread 04-04-2013, 22:02
DonRotolo's Avatar
Back to humble
FRC #0832
Re: A Different Solenoid Breakout Output Voltage Issue
What are you using as a voltage source?
Unread 04-04-2013, 22:17
jbsmithtx's Avatar
jbsmithtx jbsmithtx is offline
FIRST Fanatic
AKA: Josh Smith
FRC #4206 (RoboVikes)
Rookie Year: 2012
jbsmithtx is a jewel in the roughjbsmithtx is a jewel in the roughjbsmithtx is a jewel in the rough
A couple things to check:
1) Input voltage
2) The breakout board itself
3) Wiring (the solenoid wires usually have to be spliced)
And I remember now for some reason that our sidecar had gone out, and literally everything was working except our signal light and the pneumatics. I currently can't remember why, because our pneumatics was nowhere near connected to the digital sidecar. I searched into this problem for MONTHS, and after we swapped digital sidecars, it worked. Sidecars tend to be a little fragile.
Unread 04-04-2013, 22:50
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
Rookie Year: 2011
theawesome1730 will become famous soon enough
It's quite possible that if you are running the breakout on 12 volts that you have a 24 volt solenoid mixed in by mistake. It's not a hard fix if all your solenoids are 12 & 24 volt compatible
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 05-04-2013, 08:00
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
Rookie Year: 2012
gixxy is on a distinguished road
Where could someone purchase 12/24 tolerant solenoids? Those would be amazing to have!
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 05-04-2013, 11:31
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
analog channel 5? Are you sure? Solenoids aren't analog devices.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
