Re: Dry Ice on Robot?
As to how you could use dry ice to provide power to a robot... YouTube: Stirling Engine Running On Dry Ice. Maybe you could use the Stirling engine to power a fan to cool your motors? The energy for this would, as you point out, not be coming from the dry ice but from the ambient temperature, and under those terms could be ruled illegal. |
I would rather touch dry ice than an 8 inch pneumatic wheel spinning at 5000 RPM...
"G53: Ambient energy of any form present within the boundaries of the PLAYING FIELD may not be harvested and employed by a ROBOT. This includes; thermal energy present in FIELD ELEMENTS, carpet, atmosphere, or other ROBOTS; radiant or photon energy from venue lighting; acoustic energy from the PA system or spectators; and magnetic or cosmic energy fields or streams which may exist within the venue. Violation: TECHINCAL FOUL" |
Further to this thought, even if dry ice were to be considered an "energy source", would it not be included under the "deformation of robot parts". After all, the energy would come from the thermodynamic expansion of a gas, which is specifically legal in a closed-loop gas shock... which means the gas is a robot part and it is allowed to deform. I challenge anyone to find a rule prohibiting phase changes! A logical thought experiment... would it be legal to leave the dry ice on the motors while queuing, then remove it immediately before going on to the field? I'd say "yes"... which means that having thermal gradients is legal. (An interesting thought... for teams using off-board compressors... chill the air in your aluminum storage tanks, and place them above your warm motors... as the match goes on you might get a bit more energy out of them.) If we really wanted to find excuses to not allow Dry Ice on the robot, we could try classifying it as "compressed air", and as it was compressed by a source other than the compressor then it might not be legal. However since "air" is primarily nitrogen, and Dry Ice is CO2, that would really be stretching it. In short, however, if the dry ice was handled safely, and placed on the robot in a secure manner, unlikely to injure competitors or officials, and unlikely to damage the field or other robots.... it would be up to the event officials to explain under what rule they were disallowing the dry ice. If they couldn't do that, then they would be obliged to rule the dry ice legal. And why not? I mean, it's just dry ice! I shared the same "gut feeling" as the cat at the top of the page, but after looking at all the rules... I'd have to pass it at inspection. Jason Last edited by dtengineering : 10-04-2013 at 00:36. |
Interesting arguments though |
No Prohibited Materials – e.g. sound, lasers, noxious or toxic gases or inhalable particles or chemicals <R08>Referring to Sec 4 of the Game Manual: R08 ROBOT parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition, or interfere with the operation of other ROBOTS.Dry ice poses handling and asphyxiation risks. Also, if dry ice is put in a tightly closed container, the container may burst. The grey area is if the dry ice is not part of the robot, but instead is used to cool components between matches, etc. In this case, dry ice is no longer an inspection issue, but the safety advisers may prohibit its use in the pits. |
Precisely....we joked about using dry ice to create smoke trails for our frisbees ...one can dream...
Dry ice, sometimes referred to as "Cardice" or as "card ice" (chiefly British English), is the solid form of carbon dioxide. It is used primarily as a cooling agent. Its advantages include lower temperature than that of water ice and not leaving any residue (other than incidental frost from moisture in the atmosphere). It is useful for preserving frozen foods, ice cream, etc., where mechanical cooling is unavailable. (wikipedia) Quote:
There are far better ways to cool motors. Cooling fins, Heat sinks, airflow. Did you want to create a mystery mist around your Robot? Kind of like the lighting schemes that many teams use? |
#10
I'm surprised no one has yet mentioned that if you release any CO2 gas, then you are violating rule G13:
G13: ROBOTS may not intentionally detach or leave parts on the FIELD. Violation: TECHNICAL FOUL |
#11
Do we now have to capture any air released from pneumatics?
#12
Just go to the question box and ask to be shown the detached part(s).
#13
I like balloons though...note to self, start getting penalties for left behind pneumatic air
#15
Not the result I want. Dr. Bob Chairman's Award is not about building the robot. Every team builds a robot. |
