Go to Post You can take my blocker... but you can never take my cheesecake! - Andrew Schreiber [more]
Unread 11-04-2013, 22:47
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
Using Discs to Block Full Court Shooters
At the two events I've been to this year, full-court shooters (948 and 4334) were on the winning alliance. The general strategy was to have the FCS get into position and the #3 pick run interference to keep the opposing alliance's "blocker" robot away.
Alliances without a "blocker" may as well have packed up and gone home, but a good blocker could really cut down on the effectiveness of even the best FCS machines.
The rules clearly limit a "blocker" robot to 84" in height, but I can't seem to find anything that would prevent a blocker from grasping a disc and raising the disc above 84". Likewise, while a robot may never exceed a 54" cylinder, a disc is certainly allowed to leave the cylinder.
For teams heading to St. Louis, knowing that they aren't a great shooter, and are only a 10 point climber, would it not be possible to use the 30 pound withholding allowance to build a lightweight mechanism that would grasp three discs using grippers right at the edges of the robot size envelope, and become a blocker with an effective height of 94" and width of 60+"?
A quick sketch would explain this even better... but if you've read this far, you probably get the idea. I feel kind of bad suggesting this, because full court shooters that can rapidly hit "three" after "three" are a thing of beauty. (Yeah, 948, that's you I'm talking about!)
But just think how much more effective a shot blocker could be if they were using the discs to extend their reach.
Jason
Unread 11-04-2013, 22:51
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Re: Using Discs to Block Full Court Shooters
It's an interesting concept, and I must say that when I read the title of the thread, I thought you were talking about using discs in a "PULL!" fashion!
I'm not sure how the ruling would go on this one, but from a quick skim I would say that it'd be a legal idea.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016) | FTC Referee (2017)
Academic Student (Forever)
Unread 11-04-2013, 22:53
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
This is what I thought of: http://www.chiefdelphi.com/forums/sh...d.php?t=105023
Unread 11-04-2013, 23:04
zmeves's Avatar
zmeves zmeves is offline
AKA: Zach Meves
FRC #3847 (Spectrum)
Team Role: Driver
Rookie Year: 2011
zmeves is an unknown quantity at this point
Interesting idea. The rules limit the FCS to 60", however, so any 84" tall robot should be able to block of its own accord. There are very few disc flight paths that will pass over the blocker and still make a goal. If launched at the steepness of angle required to go over the blocker, a disc will reverse direction once it drifts back down.
Unless the FCS was a "hammer-bot"....
-Zach Meves
FRC #3847 Spectrum
Unread 11-04-2013, 23:02
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Hmm...
Off-hand, I can't think of any rules that it would violate. However, I do think that this is pushing the envelope a little too far, and if implemented with any success will result in a rule for next year reading something to the effect of "Robots may not use game objects in their construction" and another to the effect of "Robots may not intentionally use game objects to interfere with other game objects".
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 11-04-2013, 23:07
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Rookie Year: 2012
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Originally Posted by EricH View Post
Hmm...
Right, not to mention the fact that a 70"-90" actuating blocker would probably not be limited to success in blocking FCS robots. At 70", you're right in a lot of pyramid runners' flight paths.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 11-04-2013, 23:15
zmeves's Avatar
AKA: Zach Meves
Team Role: Driver
Rookie Year: 2011
Any robot attempting to block another's pyramid shot can only be 60" tall, you can only be over 60" inside your Autozone (which is where opposing FCS's shoot from)
-Zach Meves
FRC #3847 Spectrum
Unread 11-04-2013, 23:18
Woolly's Avatar
Programming Mentor
Rookie Year: 2012
70" is taking into account the height of the Frisbee on top of your 60" blocker while allowing a 1.5" grip on the Frisbee.
Unread 11-04-2013, 23:27
zmeves's Avatar
AKA: Zach Meves
Team Role: Driver
Rookie Year: 2011
Ah, understood. I misread it at first.
Yes, that could make a difference for blocking pyramid shots if the robot could maintain a grip on the disc while holding up to some very hard shots.
-Zach Meves
FRC #3847 Spectrum
Unread 11-04-2013, 23:30
CalTran's Avatar
Missouri S&T Senior
Rookie Year: 2010
And could have been our chance to block some of your shots at Razorback...but alas your shots cleared our noodle tips.
Unread 12-04-2013, 15:55
zmeves's Avatar
AKA: Zach Meves
Team Role: Driver
Rookie Year: 2011
I well remember being afraid of you blocking our shots
-Zach Meves
FRC #3847 Spectrum
Unread 15-04-2013, 15:30
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Q&A is in:
Q623 Q. Do DISCS under the active control of a ROBOT count towards the limits defined by the PLAYING CONFIGURATION? STARTING CONFIGURATION?
A. No. No.
Not surprised but I wish I had thought of the idea earlier and made a robot designed to be 70" in the opponent's auto zone. Also a robot that ferries discs.
Unread 15-04-2013, 15:46
efoote868 efoote868 is offline
foote stepped in
AKA: E. Foote
FRC #0868
efoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond repute
Since you get three frisbees at the start, you could try and wedge the third frisbee in between the first two, and increase your effective height even more.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 11-04-2013, 23:19
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
But if you were to have your blocker rigged such that everything except some number of discs (less than or equal to 4, of course) were able to drop below 60", could the refs call you for being above the height limit?
Not if it was retracted. Not under current rules. But the effective blocking height is going to be closer to 70" than 60".
Past teams:
  #15   Spotlight this post!
Unread 11-04-2013, 23:38
AKA: Simon Bohn
Rookie Year: 2010
Looks like a good one for Q&A. Posted:
Q623:
(Come one guys, we can make it to Q639!)
