Go to Post An awesome unveiling video is not necessarily an indicator of onfield performance. - ToddF [more]
View Poll Results: Command Based or Iterative?
Command-Based 17 51.52%
Iterative 14 42.42%
Other (Custom RobotBase, etc.) 2 6.06%
Voters: 33. You may not vote on this poll
Unread 04-12-2013, 03:29 PM
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
Rookie Year: 2012
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
Command-Based or Iterative
Which one do you use? Yes, I'm aware that Command-Based uses IterativeRobot, but I'm more referring to whether your team uses Command-Based or not.
Please feel free to explain why too, to help teams that don't know which one to go with.
All opinions are my own.
Unread 04-12-2013, 03:46 PM
AKA: Joel Gallant
Rookie Year: 2012
Re: Command-Based or Iterative
I'll start off with my reasons to use IterativeRobot instead of Command-Based. Note that this is my opinion only and I completely understand the benefits of both systems.
We use iterative because it lets us do things like this. We can make as many "Robot" classes and switch between them with a simple array. Along with this, we can use this class to call all of the methods within it, and catch any errors. This eliminates a lot of the frustration that comes with NetConsole and Netbeans being needed to debug. Using Iterative also lets us custom tune loops, threads and other things that are kind of "taken care of" in Command-Based. For a lot of people it makes it easier, but I'm a big fan of our custom loop times, delays and fixed-rate execution. Sure we could do it in command-based, but then a lot of the point of command-based is gone.
The part of command-based (well, the idea) we use is Commands. Yes I know that sounds ridiculous, but we have this class that lets us call run() anywhere we need to. We have some basic commands that perform actions on interfaces ("SetteableNumber", "SetteableBoolean", etc.). It lets us not get clogged up in commands that use specific subsystems. (eg. requires())
Iterative also makes Gordian deadly simple to use. Calling new Gordian(stringFromFile).run() in autonomousInit() beats anything else I've ever used.
I also hate the performance of Scheduler. We spent a lot of time dealing with problems I've found rooted in Scheduler not running consistently. (Specifically SmartDashboard buttons)
Unread 04-12-2013, 04:19 PM
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
We use command-based because it provides a framework with some degree of abstraction which is also fairly well documented and supported.
Our software team usually consists of 1-2 students plus me, and I'd rather act as a mentor than a programmer. My job is to be a safety net, giving the students a sense of confidence so they can try to solve problems that they may not attempt if the success of the season was solely on their shoulders.
If we were creating much more sophisticated robots then I see the advantages of a bespoke framework, but command-based provides a good sandbox for learning about OO-design, modularity and maintainability.
Unread 05-27-2013, 10:57 PM
Cel Skeggs Cel Skeggs is offline
Robot Software Manager Alumnus
AKA: Previously known as Colby
FRC #1540 (The Flaming Chickens)
Cel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of light
We use IterativeRobot. This is mostly because we switched to Java last year (so we've used it for two years) and it worked well enough for us both years.
I see the Command-Based framework as writing a large amount of code for you, which makes it much harder to debug when a program doesn't work.
We also have a Java class being taught separately at our school, so we can require that all Software students are taking this class or have equivalent experience, so that we don't need to worry about teaching anyone how to program.
We haven't actually programmed our robot using the Command-Based framework yet, but if we're going to use a complex framework, we'd rather write the framework ourselves during the preseason (and release it, of course), so that we have someone on our team who knows how the framework works and how to extend it.
Software manager alumnus. Developer of the CCRE, a powerful robot code framework based on dataflow and composibility.
Refer to as she/her/hers. Years of FRC: 2012, 2013, 2014, 2015, 2016. FLL for a few years beforehand.
Team 1540: The Flaming Chickens | Portland, Oregon | Twitter | Facebook
Unread 05-28-2013, 11:27 AM
connor.worley's Avatar
connor.worley connor.worley is offline
FRC #0973 (Greybots)
Rookie Year: 2010
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
We use IterativeRobot, C++
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 05-28-2013, 12:26 PM
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
From what I've seen, I think command-based is easier to use for "simple" stuff. Being able to use command groups, having the built in sequential/parallel functions makes it pretty simple for teams to get fairly complex behavior from their machines.
That said, the implementation of command-based, command groups, and the like does make doing some stuff harder...
I mentioned it in another thread a while ago, but to reiterate... our climbing sequence was really easy to create as a command-based sequence - each step followed the next, and we ended up at the top of the pyramid. However, we encountered some difficulties adding more complex behavior to the sequence. For example, how do we tell it to stop the sequence halfway through and restart? How do we tell it to back up one step? In the end, we determined that adding these behaviors was something we didn't have time to do (including testing to make sure they worked as intended with no side-effects!). As a result, there were a couple of matches this season where we were unable to successfully climb.
Now, if we had set this up iteratively, it would have been a little harder initially, as we would have had to create the sequential/parallel structure we used, using internal variables and conditionals. However, it would have been very easy for us to then manipulate those variables to adjust our position in the sequence.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
