Go to Post Inspect every connection after every match. Use your eyes, ears and nose. - Al Skierkiewicz [more]
  #16   Spotlight this post!
Unread 14-04-2013, 20:07
bs7280 bs7280 is offline
FRC #3734
Team Role: Leadership
Rookie Year: 2011
bs7280 has a spectacular aura aboutbs7280 has a spectacular aura aboutbs7280 has a spectacular aura about
Re: Help Identifying part
Originally Posted by CENTURION View Post
As others have said, those are lazy susans. I would be hesitant to use them in a swerve drive. If you put any significant side load on them (Which can happen very easily on the field), I've seen the bottom and top halves of them pull apart and warp, which ruins them very quickly.
After doing some research and designing, we probably will not use lazy susans for the reason you said. We do however have a possible solution for the piece pictured above.
Although it will definitely not be as eloquent as Neutrio's swerve drive.
  #17   Spotlight this post!
Unread 14-04-2013, 20:10
JChang JChang is offline
AKA: Josh Chang
FRC #0868 (TechHOUNDS)
Team Role: Driver
Rookie Year: 2010
JChang will become famous soon enough
The 221 Revolution 2 Swerve module uses thrust needle roller bearings, they can be found here. That is the silver ring on your first picture.
  #18   Spotlight this post!
Unread 14-04-2013, 20:16
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Rookie Year: 2011
Jibri Wright will become famous soon enough
Ya we were thinking of using lazy susans for our prototype swerve modules as well but decided not to because we were afraid of this happening.
You know someone likes something when after doing it a million times, they still marvel at it as if it was the FIRST.
Greatness asks how can I make it better. Genius asks how can I make it different.
  #19   Spotlight this post!
Unread 14-04-2013, 20:27
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Well to be fair, very few swerve units will be as elegant as Neutrino's
Yeah, we had a lazy susan on our minibot deployer in 2011, after slamming it into the pole fifty or sixty times, it was totally shot.
Can I ask what your solution was?
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
  #20   Spotlight this post!
Unread 14-04-2013, 20:52
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
Rookie Year: 2011
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
No they don't... The 221 Revolution 2 Swerve Modules just have a bronze bushing to separate the steering from the drive shaft.
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
  #21   Spotlight this post!
Unread 15-04-2013, 00:39
FRC #3734
Rookie Year: 2011
I think you are right, but it does look like they have some type of bearing in the picture. I emailed the company and they said it was a custom part that "houses a large bushing". Large is indeed right and I am having trouble finding one that large.
