Go to Post "Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world." - Albert Einstein - Edward Debler [more]
Unread 14-04-2013, 14:04
tinybob20 tinybob20 is offline
AKA: Jeremy
FRC #1559 (DevilTech)
Rookie Year: 2012
tinybob20 is an unknown quantity at this point
Bad Lag
Our team has gone to two regionals this year. At both we have experienced large amounts of lag between our control system and robot. After our first competition, we decided to take a shotgun approach to fixing the lag. We had originally written or code in Java with the simpleRobot template, so we tried writing it in Iterative, both with and without a separate thread for the drive system. We did find that the Iterative without a thread for drive improved the lag issues, but a newer issue seemed to emerge. We would see the robot stop for a bit, drive for a bit, then stop again, repeating over and over. The drive logs did not show any lost connections. If anyone has had this issue and was able to solve it, it would be great if you could show us how to fix this.
