Go to Post Moreover, lets discuss robots, its more fun :p - Bharat Nain [more]
Unread 14-04-2013, 17:05
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
Integrated WCD "Warp drive" chassis
I'm working on a off-season drive train project for our team. It takes some cues from the WCD.
It's made from 3 X 3" .120" box tube and uses the VEX ball shifter with a modified 3 stage with 34:50 gearing. The rear VersaWheel is directly driven and then chained to the middle VersaWheel with two sprockets, This wheel is then chained to the 3rd.
The top of the chain runs inside the tube on and outside on the bottom chain for easy tensioning.
Has anyone done anything similar to this? Any comments?
ID:	14607  Click image for larger version
ID:	14608  Click image for larger version
ID:	14609  Click image for larger version
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Ref, Inspector
Unread 14-04-2013, 17:17
nerdherdmember's Avatar
nerdherdmember nerdherdmember is offline
#letsdothis
AKA: Harrison (That kid with the blue hat)
FRC #0422 (Mech Tech Dragons)
Rookie Year: 2010
nerdherdmember is a jewel in the roughnerdherdmember is a jewel in the roughnerdherdmember is a jewel in the roughnerdherdmember is a jewel in the rough
Re: Integrated WCD "Warp drive" chassis
This reminds me of the Rock Box Chassis Rail from 221 Systems. The Rock Box has a very nice solution to chain tensioning in this case that you could draw inspiration from in your own projects.
Unread 14-04-2013, 17:19
AlexH AlexH is offline
Rookie Year: 2010
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
chain inside box tube is a pain in the @$$ to work with. unless you have access holes that i'm not seeing, its going to be really hard to get chain on the sprockets.
i was not really impressed with the versa wheels. in my experience they wear down really fast. my team ran them for about an hour of practice driving and 10 matches before they pretty much balded. picture (i understand that other teams have not had the same issues with the versa wheels wearing down that fast)
My Instructables
Unread 14-04-2013, 17:22
mman1506's Avatar
no team (WARP7)
Rookie Year: 2012
Wow that wear is staggering, how was the traction when they were balded?
The Chain runs outside the tube for half it's run so it shouldn't be two hard. I'll be adding more lightening holes soon so it should make it easier to access.
Unread 14-04-2013, 17:20
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Wouldn't it be better to run the chain on the outside over the top, and on the inside on the bottom? Might make it easier to tension, rather than having to get under the robot. And also might avoid any issues with the chain damaging field elements/game pieces?
Oh, and yes, similar things have been made before, Andymark has been selling these for a couple years now.
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 14-04-2013, 17:25
mman1506's Avatar
no team (WARP7)
Rookie Year: 2012
The wheels are too small to do that sadly but the chain height would be the same as putting the versawheels on the vexpro chassis
Unread 14-04-2013, 17:39
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
what is the advantage of this over cantilevering wheels?
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 14-04-2013, 17:44
mman1506's Avatar
no team (WARP7)
Rookie Year: 2012
its lighter as you don't need the blocks and it leaves a little more space inside the robot. You also don't have to worry about wires getting caught in it as much.
Unread 14-04-2013, 17:53
Rookie Year: 2010
You might want to consider some way of tensioning chain
Unread 14-04-2013, 18:44
mman1506's Avatar
no team (WARP7)
Rookie Year: 2012
I noticed that the vexpro chassis doesn't have any way of tensioning the chain and I'm hoping the relatively large sprocket surface will prevent the chain from slipping. If it becomes a big issue I will probably add a sliding delrin slider or implement something like the rockbox.
Unread 14-04-2013, 18:48
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
While definitions of WCDs vary, virtually all include cantilevered wheel shafts and sliding bearing blocks for chain tensioning.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 14-04-2013, 19:24
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
I designed a similar system (technical term/name for this style of drive is 'nested tube', see notes about WCD above) in 2011 when I was on 816 and it worked reasonably well, although servicing it was a complete pain - or at least when servicing anything out of the norm. Here are some pictures:
Frame: http://www.chiefdelphi.com/media/photos/36107
Completed Chassis: http://www.chiefdelphi.com/media/photos/36163
Some general specs:
Drop Center 6WD
6" AM Plaction Wheels, Roughtop Tread
AM Super Shifters, Standard Gearing
Direct Drive Center Wheel, #35 Chain to outer wheels.
That drive didn't have any method of tensioning* and we never had any issues with the chain tension through two regionals and the off season. The drive only ever had one major failure that I can remember - the tread on one of the wheels came off and lodged itself in between the wheel and the tube.... Other wise, aside from needing to swap out the roll pins in the Super Shifters for 4-40 screws (or the other way around, it's been a while) the drive was solid.
* The Chains were 'dead spaced' meaning that they were spaced on exact center to center distances. #35 chain is really easy to dead space as it's a bit more forgiving to misalignment and weird tensions, #25 is a little more difficult, primarily due the tighter tolerances on tension and misalignment. (341's drive this year has a total of 6 #25 chain spans that have been dead spaced, no issues yet *knock on wood*)
Another note on dead spacing in drive applications, I only recommend doing so if one of the wheels is direct driven from a transmission. If one wheel is direct driven and all other wheels are chain driven a lost chain shouldn't render the entire drive useless for the rest of the match.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 14-04-2013, 19:48
connor.worley's Avatar
connor.worley connor.worley is offline
FRC #0973 (Greybots)
Rookie Year: 2010
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
WCDs also typically direct drive the center wheel off the transmission. This means that both chains must fail to lose both additional wheels. Will you able to quickly replace wheels on this chassis? (WCD cantilevering speeds up wheel replacements).
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 14-04-2013, 20:12
mman1506's Avatar
no team (WARP7)
Rookie Year: 2012
Each module is only about 60$ of parts without the shifter and we can machine it in our school so if we were to implement it in a comp bot we could just build backup modules. The wheels shouldn't be that tricky to replace, once the chain is removed you just slide it out of the bottom.
  #15   Spotlight this post!
Unread 14-04-2013, 20:33
mman1506's Avatar
no team (WARP7)
Rookie Year: 2012
Some general specs:
Drop Center 6WD
wow, could you explain more about how to dead space the chain?
