Go to Post You valuable advice has prevented me from killing myself and others numerous times =) - Stephen Kowski [more]
Unread 04-16-2013, 07:48 PM
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Alliance Scores Histogram
Weeks 1 thru 7: ... 77 Events, 2509 Teams, 12806 Alliance Scores for 6403 Qual Matches.
Name:	Alliance Scores Histogram.png
ID:	14622  Click image for larger version
Last edited by Ether : 04-16-2013 at 11:41 PM. Reason: added ogive graph with finer resolution
Unread 04-16-2013, 09:18 PM
ablatner ablatner is offline
AKA: Andrew Blatner
FRC #0100 (The Wildhats)
Team Role: Leadership
ablatner is on a distinguished road
Re: Alliance Scores Histogram
Could you post the data as an ogive?
2009-2013: Student, Team 100
2013-????: ?
Unread 04-16-2013, 10:12 PM
Ether's Avatar
Rookie Year: 1969
Yes.
Unread 04-16-2013, 10:27 PM
AKA: Andrew Blatner
Thanks!
2013-????: ?
Unread 04-17-2013, 12:51 AM
Dreams2Reality Dreams2Reality is offline
FRC #2474
Dreams2Reality is infamous around these partsDreams2Reality is infamous around these partsDreams2Reality is infamous around these partsDreams2Reality is infamous around these parts
Can you post a chart for MSC only as a comparison?
Unread 04-17-2013, 08:52 AM
Ether's Avatar
Rookie Year: 1969
Unread 04-17-2013, 09:30 AM
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Yeeeeah. MSC was a whole different game. The competition level was unmatched, the only regionals that even got close were Waterloo and GTRWest, and they don't even hold a candle to it.
Way to go Michigan!
Unread 04-17-2013, 10:11 AM
Ether's Avatar
Rookie Year: 1969
Way to go Michigan!
Unread 04-17-2013, 11:26 AM
That last graph is a bit deceiving since you took the 'all events' line off.
Visually, GTRWest+Waterloo look like they match the 'all events' line, relative to MSC, but in actuality, they're quite a bit stronger if you look at the numbers.
Unread 04-17-2013, 11:34 AM
The graphs are interesting though.
Unsurprising that GTRW/Waterloo are very similar (both late season, both in the same geographical region, and both with MANY of the same teams).
Whats interesting to me is the slope differential. MAR seems to have a taller slope (which I believe equates to a narrower band of 'average' scores, meaning tighter competition), but the top end lines up with GTRWest and Waterloo fairly well, while MSC is stronger.
I think that would suggest that GTRW/Waterloo/MAR all have fairly similar max-score (which I would say is primarily a function of the 'best 2' robots), while MSC is higher throughout the curve. It also suggests to me that MAR's midrange teams are on average stronger, which makes sense, since its an invitation only event.
Unread 04-17-2013, 11:46 AM
M.O'Reilly M.O'Reilly is offline
AKA: Mike O.
FRC #4637 (BambieBotz)
M.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of light
I think the data actually suggests that max match scores at the Canada events were higher than MAR (b/c of aforementioned teams), but there was a faster drop-off in competition after the top teams. Whereas MAR had lower maximums and consistently higher average scores as you said. The lack of many floor pick-up bots, and fast 30 point climbers kept max scores in check. Matches were shoot 'til you die, and if you can't cycle 4 times, you can't keep up, so play defense. In nearly every elim. match, at least one side went through all white and colored discs at the loader station.
Unread 04-17-2013, 11:42 AM
AKA: Mike O.
Pretty cool/relieving to see the data support that MARC was a tough event. Not as tough as MSC, but also there are about half the teams in the region, so the competition won't be quite as high at MARC. Until this point, MARC was receiving a lot of criticism for well known teams declining to attend. I also couldn't help but notice that the game strategy in the region was a little different than every where else due to the defensive, rough-and-tumble nature of many teams in the area. Motors ran hot at the conclusion of each match.
Unread 04-17-2013, 12:56 PM
Ether's Avatar
Rookie Year: 1969
A histogram may answer some of the questions.
Unread 04-18-2013, 09:21 PM
DonRotolo's Avatar
Back to humble
FRC #0832
Well, that 171 score in MAR is ours...and we lost that match
Thank you Ether for posting all this data.
  #15   Spotlight this post!
Unread 04-21-2013, 01:26 PM
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
Rookie Year: 2011
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Would it be possible to report on winning match scores only?
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
