Go to Post Change 'car' to 'robot', 'coffee' to 'mountain dew' and Tom Brady to will.I.am, and you have next year's kickoff intro. - Tetraman [more]
Unread 16-04-2013, 23:54
bs7280 bs7280 is offline
FRC #3734
Team Role: Leadership
Rookie Year: 2011
bs7280 has a spectacular aura aboutbs7280 has a spectacular aura aboutbs7280 has a spectacular aura about
Coaxial Swerve drive - Steering and moving at the same time
After designing a coaxial swerve module, we have had some talks as a team about it and realized that with bevel gears, if the robot trys to power the wheel while turning the wheel the wrong direction, the gears may lock up. We are almost positive that this is true, but I just wanted to ask the CD community ahead of time.
(image example below from another team)
Unread 17-04-2013, 07:16
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
Re: Coaxial Swerve drive - Steering and moving at the same time
No, they should not lock up, however it will take more power to turn the module one way than the other when driving the wheel. The control algorithm should compensate for this with out having to take it into account. We have used straight P and a PI controller.
Unread 17-04-2013, 11:33
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
I am in agreement with Gdeaver. The miter gears should not lock up regardless of how the wheels turn.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 17-04-2013, 11:51
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
The gears don't lock up, but there is an interaction between the drive and steering motors.
If the drive shaft (the vertical shaft shown in your picture) is held fixed and you steer the wheel, the wheel will also rotate about its axis.
If you apply a fixed torque to the drive shaft, then the wheel will speed up or slow down a little as you are steering it.
Unread 17-04-2013, 14:14
FRC #3734
Rookie Year: 2011
Thank you everyone, this answered my question
